Dieseldawg
Member
- Joined
- Nov 20, 2012
- Messages
- 8
- Reaction score
- 0
99 F350 Lariot interior, Touch Screen CD/MP3 player, Power Seats, All Auto Meter guages (2 boost, Drive Pressure, oil Pressure, EGT, Tranny Temp, Fuel Pressure, Water Temp). But all aren't hooked up yet the interior still needs a little work but that's not why you buy a truck like this anyway.
Full 05 Front end conversion
Industrial block 12v
Fresh Rebuild before the swap.
12mm pump w/ 4K GSK, Full Cut DV's, Custom in cab adjustable AFC
60lb springs, ***ainum retainers
Fire Ringed, 12mm studs
.093 lines
Brand new 5x18 Injectors
Electric Fan
Engineered Diesel Built Triple turbos
2 62/71's over a 64/71
4" Silverline Rear Exit Exhaust, 5" tip
HTS Full Billit Trans
Double Deep Pan
SunCoast Converter
TS Tranny Controller but right now not hooked up overdrive and tq lock up on switches.
Now it isnt any show truck, but it still looks bad ass! It's got 8" lift with 325/60/20 with Micky Thompson wheels. I know the truck still needs some work but it's the only one like it no other I mean sure other guys have cummins in there trucks but not like this, it was built to pull so it's not fast and it smokes a lot.right now it has a turbo that needs a rebuild and it needs a rear main seal. Theres more than 30k in the drivetrain. Im just not home enough to finish it and I have too many other projects that come first. If you want the baddest truck around I have it. my number is 6155093279 I prefer txt but if you call leave a message and I'll get back to you. comes with spare front hubs. The head is also new. Possible trade for buggy.
<div style="width:480px;text-align:right;"><embed width="480" height="360" src="http://static.pbsrc.com/flash/rss_slideshow.swf" flashvars="rssFeed=http://feed1311.photobucket.com/albums/s667/dieseldawg21/feed.rss" type="application/x-shockwave-flash" wmode="transparent" /><a href="http://photobucket.com/redirect/album?showShareLB=1" target="_blank"><img src="http://pic.photobucket.com/share/icons/embed/btn_geturs.gif" style="border:none;" /></a><a href="http://s1311.photobucket.com/albums/s667/dieseldawg21/" target="_blank"><img src="http://pic.photobucket.com/share/icons/embed/btn_viewall.gif" style="border:none;" /></a></div>
.093 lines
Electric Fan
Double Deep Pan
SunCoast Converter
