knaffie
9/29/12.... SOLD
1995 S10 ZR2. Well over $25,000 in parts and hundreds of hours of labor were used to build this truck over the last 6 years. This is absolutely a “one of a kind” truck. This is an extremely dependable, turn-key rig. All the bugs have been worked out of it so the owner can just enjoy it. It works great in the rocks, in the woods, on the sand, in the mud, or anywhere else – a true all-purpose rig. Drives straight down the road up to 70 MPH. All welding and fabrication has been done professionally on this truck; no “ghetto fab” can be found anywhere on this truck.
The truck is currently getting the bumpers and sliders repainted, as well as the frame / underneath touched up with fresh paint or undercoating. It will look as good or better than it ever has.
BODY / FRAME / ARMOR:
• North Carolina truck that has never seen salt – rust free throughout
• ZR2 frame is fully boxed from the factory, and much stronger than a normal S10 frame
• Grille and headlights converted from S10 to Sonoma
• Custom bed, bobbed 18” between the wheel wells and the tail lights professionally finished with no evidence of the modification
• Custom fender flares to clear 42” tires with all areas of removed metal welded back in
• Front “LS1” flares by Diversified Creations with all metal removed welded back in place
• Cowl hood with custom stripe painted on
• The entire body has been repainted over the last few years
• Custom front bumper from all 1/4" plate, two solid Warn recovery shackles that go through the bumper and attach to the frame in receiver tubes
• Custom rear bumper from 1/4" plate, two solid Warn recovery shackles that attach to receiver tubes welded inside the bumper
• Rock sliders made form 2x2x1/4, 2x3x3/16, and 1.75 x .188 DOM with three 1/2" thick frame mounts
• 1/4" steel skidplate under a 1.75 x .250 DOM subframe (transfer case and lower link mount)
INTERIOR:
• Corbeau Baja XP seats (like new) with Corbeau seat mounts
• Corbeau 5 point belts with shoulder guards
• Roll bar in back seat for belt mounting and extra protection
• Custom center console from small diameter tube holding Art Carr shifter and NorthWest Fab (NWF) triple stick transfer case shifters
• Pioneer CD player, high quality OEM speakers in the door and back seat (6.5” and 4”x10”)
• CB radio installed below radio with speaker below dash, Cobra antenna, professionally tuned for SWR, works properly
• All OEM gauges work as they should (tachometer, oil pressure, coolant temperature, battery voltage, fuel level
• Triple gauge pod with transmission temperature, power steering fluid temperature, and a third gauge installed, but not hooked up (was intended for engine oil temperature), all hooked up properly with dimmable lights
• OEM carpet is in place and is clean and stain-free (recently removed and power-washed)
• OEM climate controls work perfectly (including heat), but A/C has been removed
• Dual winch controls in cab
ENGINE:
• Original 4.3L V6 (VIN W CPI), 140,000 miles, meticulous maintenance records from previous owner including synthetic oil from day 1, starts every time immediately, never stalls, no codes, runs flawlessly, includes all newer tune up items, just had the heads off, new valves installed, new head gaskets
• Proliance extra thick radiator, newer water pump, newer radiator hoses, newer belt
• High flow catalytic converter and Flowmaster muffler, oxygen sensors still in place
TRANSMISSION:
• Professionally built TH350 using 4x4 case
• full manual shifting (PRN123)
• reverse pattern
• 2200 stall
• built for 500HP
• full details of built available upon request for serious buyer
• Art Carr shifter with “rock gate” (no safety between RN1)
• Dedicated cooler (12” x 12” x 1”) with dedicated fan
• Extra large aluminum finned pan
TRANSFER CASE:
• 203/205 doubler
• everything completely torn down, sandblasted, and rebuilt with high quality components
• Chevy NP203
• Ford NP205
• extremely heavy duty doubler kit from Sumner Machine Works (SMW)
• Triple stick cable shifters from Northwest Fab (NWF)
• 32 spline outputs front and rear
FRONT AXLE:
• 1978 Ford Dana 60 high pinion
• completely stripped to bare housing, powerwashed, sandblasted, and painted with quality paint
• Reid Racing orange (aka Dedenbear) Ford style steering knuckles
• 5.38 Yukon gears
• Lockright Locker
• Yukon 35 spline chrome moly axle shafts (the good ones before the quality problems) with Spicer solid (non greaseable) joints
• aluminum drive flanges
• all newer brakes
• newer wheel studs and solid lug nuts
• newer spindle bolts and nuts
• newer wheel bearings, races, and seals,
• newer kingpins,
• Part Mike 1350 deep yoke and “u-bolt” style straps
• Great Lakes Offroad diff cover with additional 1/2" ring in the center as well as a spot to hook a winch
REAR AXLE:
• GM 14 bolt from 2002 2500HD
• Ballistic Fab shave kit and diff cover for extreme ground clearance
• 5.38 gears
• Detroit locker
• factory disc brakes
• OEM shafts
• Ruffstuff Specialties pinion guard
STEERING:
• PSC full hydraulic kit
• includes high flow P-pump, larger pulley, reservoir, double-ended ram, solid aluminum tie-rods, PSC steering arms, ARP studs, heim joints, grade 8 hardware
DRIVESHAFTS:
• Front – includes two shafts (one spare), 4 bolt flange mount, 1410 solid single joint at the top, 1350 solid single joint at the axle, professionally built and balanced, uses u-joint u-bolts
• Rear – includes two shafts (one spare), 1350 CV (one from High Angle Driveline, one from local stop), 1350 solid joints in the CV, 1410 solid joint at the axle, professionally built and balanced, uses u-joint straps
SUSPENSION:
• Front – custom dual-triangulated 4 link with 4130 heat-treated links from Heretic Fab, Currie Johnny joints (5/8” bore with 1-1/4” thread (extra heavy duty)), LH and RH on each link for easy adjustment, BDS ZJ 6” lift coil springs, Fox air bumps, Bilstein 7100 shocks, all grade 8 bolts
• Rear – SOA using Alcan custom leafs, lift shackles, custom anti-wrap bar, Bilstein 7100 shocks
ELECTRICAL:
• 140 amp AD244 alternator
• Custom dual battery setup with marine selector switch and heavy gauge wiring
• Primary cooling fan OEM Taurus fan mounted behind the radiator (puller) with Flex-A-Lite variable speed controller
• Secondary cooling fans (for transmission and steering as well as to further cool the engine) mounted directly on coolers (pushers), with Hayden thermostatic fan controller relays
• All 3 fans can be turned on or off manually at any time, or can be left to run automatically using temperature probes
• Neutral / Park safety switch bypassed so it starts in any gear
MISC:
• 42 x 15 x 17 Interco Super Swamper SX2 (includes brand new spare)
• 17 x 10 steel beadlock wheels with grade 8 hardware
• Warn 9000 winch in front with Poly Performance billet hawse fairlead and Amsteel Blue solid rope
• Smittybilt XRC8 in rear (has never been used)
• 8 rock lights mounted underneath, out of sight and out of harm’s way
• New toolbox from TSC in the bed
• High Lift jack in bed
THE BAD:
• Rear winch solenoid box is not installed and wire rope is not installed
• Several small scratches and scrapes on the body and one small dent on the bedside – although every effort has been made to keep this truck looking good, this truck is not a trailer queen, and has been used offroad
Asking $14,500. Location is Southern Michigan. Will ship or deliver for reasonable costs. If you have questions, email me [email protected]
I am looking for a newer buggy and have cash ready when I find the right one. I would do a trade + cash for the right buggy.
INTERIOR:
ENGINE:
TRANSMISSION:
• reverse pattern
• 2200 stall
• built for 500HP
TRANSFER CASE:
• 203/205 doubler
• Chevy NP203
• Ford NP205
FRONT AXLE:
• 5.38 Yukon gears
• Lockright Locker
• all newer brakes
• newer kingpins,
REAR AXLE:
• 5.38 gears
• Detroit locker
• OEM shafts
STEERING:
DRIVESHAFTS:
SUSPENSION:
ELECTRICAL:
MISC:
THE BAD:
