Sold/Expired Ultimate Jeep Axles
RCV PERFORMANCE
Strongest Axles on the Planet
Rockford, IL
Ultimate JK Axles
RCV Performance Ultimate CV Axles simply replace your Jeep JK's weak Dana 44 U-joint axle shafts with a high-strength constant velocity design. Tests prove Ultimate CV Axles to be twice as strong as OEM Jeep JK shafts, and they're just as tough at a straight angle as they are at extreme angles - where U-joints are weakest. Ultimate CV Axles also eliminate U-joint binding to allow smooth transfer power to the ground. Even if you have big tires and big power there are no worries. Ultimate CV Axles are low maintenance and operate with a smoothness you can feel - whether off road or on the street. And we back it all with a "No Questions Asked" limited lifetime warranty.
RCV Tube Seals for Standard Diameter Dana 30 and 44 Axle Tubes
Keep the dirt and grime out of your Dana 30 and 44 axle tubes with RCV Dana 44 axle tube seals. The kit comes complete with 2 re-buildable tube seals, each with 3 O-ring seals on the outer and 2 washer seals on the inner. Rebuilding these seals is quick and painless. Easy access Zerk fitting is located on the sides to inject grease. Red anodized for beauty.
Ultimate Dana 44 Rear Axle Set for Jeep JK Unlimited & Rubicon with 35 Spline ARB ('07 and up) - 300M
RCV Performance Ultimate Rear Axles simply replace your 35 spline ARB differential equipped Dana 44 rear shafts with a high-strength 300M design that is 100% MADE IN THE USA! Tests prove Ultimate CV Axles to be twice as strong as OEM Jeep JK shafts. Even if you have big tires and big power there are no worries. We back it all with a "No Questions Asked" limited lifetime warranty against breaking & bending!
Re: Ultimate Jeep Axles
Ultimate Dana 30 CV Axle Set for Jeep CJ (82-86) (Widetrack)
RCV Performance Ultimate CV Axles simply replace your Jeep CJ's weak Dana 30 U-joint axle shafts with a high-strength constant velocity design. Tests prove Ultimate CV Axles to be twice as strong as OEM Jeep axle shafts, and they're just as tough at a straight angle as they are at extreme angles - where U-joints are weakest. Ultimate CV Axles also eliminate U-joint binding to allow smooth transfer power to the ground. Even if you have big tires and big power there are no worries. Ultimate CV Axles are low maintenance and operate with a smoothness you can feel - whether off road or on the street. And we back it all with a "No Questions Asked" limited lifetime warranty.
Axle set includes right and left CV axle shafts, outer stubs, SST seals and installation tool, installation instructions, synthetic moly grease, and installation hardware. Black oxide coating is standard. Optional nickel plating is available for extra corrosion resistance in salty environments - contact us for details, or use our Custom Axle Configuration Form
For more Ultimate Jeep options, check out our website http://www.rcvperformance.com/search.aspx
Ultimate Dana 44 CV Axle Set for Jeep JK Rubicon ('07 and up)
Axle set includes right and left CV axle shafts, SST seals and installation tool, installation instructions, synthetic moly grease, and installation hardware. Black oxide coating is standard. Optional nickel plating is available for extra corrosion resistance in salty environments - contact us for details, or use our Custom Axle Configuration Form
http://www.rcvperformance.com/product-details-axles.aspx?sku=CVJ44-JK
Ultimate Dana 44 CV Axle Set for Jeep Wrangler Rubicon TJ & LJ ('03-'06)
RCV Performance Ultimate CV Axles simply replace your Jeep LJ or TJ Rubicon's weak Dana 44 U-joint axle shafts with a high-strength constant velocity design. Tests prove Ultimate CV Axles to be twice as strong as OEM Jeep axle shafts, and they're just as tough at a straight angle as they are at extreme angles - where U-joints are weakest. Ultimate CV Axles also eliminate U-joint binding to allow smooth transfer power to the ground. Even if you have big tires and big power there are no worries. Ultimate CV Axles are low maintenance and operate with a smoothness you can feel - whether off road or on the street. And we back it all with a "No Questions Asked" limited lifetime warranty.
Keep in mind we also have all the parts to rebuild your RCV axles. Just as a u-joint may wear after thousands of miles, CVs can wear as well.
http://www.rcvperformance.com/product-details.aspx?sku=D44-R
Our RCV CV Rebuild Kit for the Dana 44 includes bearing cage, inner bearing race and bearings. Cage is manufactured from aircraft quality high alloy steel for ultimate strength and then REM polished for reduced friction.
We are excited to have our Jeep axles in several SEMA show builds this year!
