Sold/Expired ULTRA4 4429 ****SOLD****
crawlin85cj
Barco Motorsports
Forney, TX
The buggy was originally built at Jim's Garage in 2009 for Travis Watford. I traded for it in October 2013 after an extensive rebuild at Jim's Garage. The buggy was torn all the way down, the chassis was inspected, repaired as needed and then new powder coat was applied. There were extensive upgrades and modifications made at this time to address any damage, weak spots, trouble areas and potential failures after a few years of use. The beauty of this is I got a fresh buggy with fresh parts that was tested and proven before the rebuild. Not having new buggy bugs has been phenomenal and it shows in the race finish record since I acquired it.
Specs...
Chassis:
2009 Jim's Garage, rebuilt in 2013 by Jim
1.75" .120 main chassis
1.75" .250 sub frame
1.75" .188 overheads
1.5" .120 fillers
Aluminum skid plate
Aluminum roof
All safety equipment required by Dirt Riot
Removable tire carrier
Removable front bumper
Dzeus fastened body panels
Full aluminum interior
Powertrain:
6.0L iron block with L92 rectangle port heads and intake
GM computer and thinned harness for ease of dyne tuning
Not sure of exact cam spec
2.5" into 3.5" exhaust
Huge air cleaner in cab
New water pump 3/2015
Griffin radiator
TH350 w/ fan cooler and heat exchanger
TCS 10" converter
Atlas 2.0 race case, new in mid 2014.
Axles:
9" front
Reid knuckles
HI9 center w/ 5.13 gears and spool
Yukon Superjoints
Wilwood 6 piston front brakes
14 bolt rear
ARB air locker w/ 5.13 gears
Full length back brace on housing
HD steel cover
Wilwood 6 piston rear brakes
Steering:
PSC super pump
PSC 8" ram
All crimped lines
PSC orbital valve
Howe trophy truck cooler
7075 tie rods
7/8" heims
Suspension:
Rear 4 link
4130 lower links
7075 upper links
All heims recently replaced
Front 2.5" KING coil over shocks
Rear KING 2.0 coil carriers and KING 2.5" 3 tube bypass shocks
PAC rear swaybar
Wheels/Tires:
5 TrailReady HD wheels
5 New BFG tires of choice if I haven't received new tires by purchase time
Misc:
Wiwood master cylinders
Wilwood pedal assembly
CNC aluminum reservoirs
Full electrical switch panel w/ circuit breakers
Siren
Horn
Rear lighting
Forward amber LED
Twisted Stitch seats
PRP ratchet harnesses
Kenwood 55w radio
PCI intercom
Jazz 32 gallon fuel cell
Dual fuel pumps in tank
Winters shifter
Warn winch
7" Lowrance GPS
$55k located in Wylie, TX.
I will deliver to any Central or South East Dirt Riot race and provide pit/tech support for the race. I am pretty sure I can also get Jim to meet there and answer any questions.
Please call with any questions, there is no way I could possibly list every detail.
214- seven 2 eight - 132 seven
Re: ULTRA4 4429 For Sale
I just finished Dirt Riot Saturday in 7th place after being the lucky recipient of 3 flat tires. Car is great, just needs a rinse and she's ready to rock with some new rubber.
By far the toughest section of the course last weekend. Multiple rollovers during the race and we got caught up in a couple traffic jams here. The 4429 went through it every time clean other than the lap we slid off the rock and went up the tree. We made it on the 2nd attempt without issue.
2010 Jim's Garage 4429
2012 Jim's Garage YJ
2013 Wide Open Design WFO
Dang......how many badass buggies you got?
Your choice of 5 90% tread BFG Krawlers mounted on TrailGear wheels with TireBalls installed, 5 new BFG Krawlers mounted on 5 new TrailReady HD wheels, 5 new BFG KR2s mounted on 5 new TrailReady HD wheels or 5 new BFG KRT-Bs mounted on 5 new TrailReady HD wheels.
Motivated. Make me a fair offer
I will keep the race radio, intercom, pumper, front amber LED, spare tire/wheel, siren, horn and spare drive lines and let her go for $45k. I need to move her to make room for a new race car!
Ok fellas, what's it going to take to get someone into this buggy??
For me..............a winning Lotto or scratch off ticket. :****: Bump for ya.
OK fellas this is all I can do and I'm going to regret this forever. $45k as is with 4 wheels and tires that can be driven on. Not new tires, 4 BFG KRT-B tires and TR HD wheels. Everything else stays. The car will be prepped to race when you get it.
Any lower than this and I will keep it and do who knows what with it.
The plan is to put my kiddo in WFO when my new buggy is finished. I need to find a good home for my U4 car, I can't keep up with maintaining 3, much less 4 rigs.
Get it to PA and I will maintain it for you. I will treat it real nice and only drive it on the weekends.
No realistic offer refused!
$40k. Someone buy this. It's a great car and ready to rock!
Come out and visit it at AOP next weekend.
You can guarantee I will be toting my helmet and giving it a go or 3.
