Sold/Expired Unbelieveable Pricing on Barnes 4wd Chromoly Heim Joint Kits!
Barnes 4wd
Unbelievable Pricing On Heim Joint Kits from Barnes 4WD!
Our heim joint kits come with everything that you need for one control arm end at an unbelievable price! Each kit comes with one heat treated chromoly heim, jam nut, tube insert and two high misalignment spacers. Check out the prices below, and click on the links for more info. You wont find better prices on a quality rod end anywhere:​
Heat Treated Chromoly 1.25" Rod End Kit - $50.24
Heat Treated Chromoly 7/8" Rod End Kit - $26.74
Heat Treated Chromoly 3/4" Rod End Kit - $21.34
Heat Treated Chromoly 5/8" Rod End Kit - $16.86
We also carry square tube heim joint kits:
Heat Treated Chromoly 1.25" Square Tube Rod End Kit - $55.10
Heat Treated Chromoly 7/8" Square Tube Rod End Kit - $32.92
We still have low prices on these high quality joints. We have both square and round tube ends available, find them all here:
Each kit includes:
-1 Heat treated Chromoly Heim
-1 Jam nut
-1 Tube insert (round and square tube available)
-2 High misalignment spacers
Chris May has been using our Chromoly Heim Joints on his 4400 class Ultra 4 car and his other builds over the years with great success. He has also used our tube inserts, misc brackets, tabs and tons of other small parts on this car.
Check out more photos of Chris's rig here: Yota Off-Road Racing
Our Heim Joint Kits are always in stock! If you have any questions about an order, or can't find what you are looking for, let us know. Call us at (828) 551-7616 or email [email protected] with all your questions.
Each kit comes with the following:
  • Heat-treated chromoly Heim joint
  • Weld in tube insert
  • Jam nut
  • 2 High Misalignment Spacers
Heim Joint Installation & Sizing Tips:
  • 3/4” heims: These heims are great for steering and upper links on lighter weight rigs.
  • 7/8” heims: These heims can be used for steering applications with a 3/4” bore. They are also great for upper links on medium to large rigs and can be used as lowers on lightweight rigs.
  • 1 1/4” heims: These are most commonly found on lower links on rigs of all sizes. They’re strong and wear slower than smaller heims due to increased surface area on the liner. They can also be used on upper links, offering much longer service life in that application.
  • When installing a heim joint, it is best to use anti-seize lubricant on both the threads and high misalignment spacers. This will allow for easier maintenance and adjustment down the road.
If you’re looking to swap out your suspension with a link system, check out Barnes’ line of 3 link suspension kits and 4 link suspension kits. You might also be interested in:
We always keep our Heim Joint Kits in stock. We recently revised our website to make choosing options for each kit a breeze. If you have any trouble let us know.
We keep our Heim Joints in stock, check them all out here.
  • Jam nut
Subscribe to our Newsletter for Discount Codes and New Product Releases!
Be sure and check our website daily for the deal of the day!
Are the above still happening? I have not heard much from you guys lately.
We had an extremely busy weekend! Thanks Hardline!
Please look at our rules. They do not allow for unnecessary bumping of vendor threads.
JohnG
Admin.
Thanks John, we read them. We don't feel its unnecessary bumping, we have hundreds of products and try to keep them in the public eye. With that being said, we only bump 2 threads per day which we feel isnt hindering anyone. If this needs to change please send us a PM and let us know how you would like us to promote.
Thanks!
