Sold/Expired Universal 3 link kits at Barnes 4WD
Barnes 4wd
Barnes 4WD Universal 3 Link Kit
All Kits ship with brackets pre-drilled to the correct bolt hole size and no extra cost!
This is the kit that has all the parts that we are always using in the shop for customers three links suspensions. Our kits are built to stand up to the abuse that rock crawlers, weekend warriors, and daily driven rigs see. This kit includes:
1 x Axle Link Mount Pair 10 Deg
1 x Frame Link Mount
1 x Adjustable Inner Frame Link Mount Pair 0 Deg
1 x Link Tower
1 x Outside Frame Panhard / Trackbar Mounting Bracket
1 x Offset Axle Panhard Bracket
1 x Chromoly 3/4 - 16 X 3/4" Heim RH
1 x Chromoly 3/4 - 16 X 3/4" Heim LH
2 x High Misalignment Spacer - 3/4" to 5/8" (pair)
1 x 3/4" - 16 Jam Nut RH
1 x 3/4" - 16 Jam Nut LH
1 x Tube Insert (3/4-16) 1" ID Tube RH
1 x Tube Insert (3/4-16) 1" ID Tube LH
3 x Chromoly 1 1/4"- 12 X 1" Heim RH
3 x Chromoly 1 1/4"- 12 X 1" Heim LH
6 x High Misalignment Spacer - 1" to 5/8" (pair)
3 x 1-1/4" - 12 Jam Nut RH
3 x 1-1/4" - 12 Jam Nut LH
3 x Tube Insert (1-1/4-12) 1 1/2" ID Tube RH
3 x Tube Insert (1-1/4-12) 1 1/2" ID Tube LH [/SIZE]
Find it here for $505
