Sold/Expired Universal Sway Bar
BamaTJ
Hardline Crawler
Gardendale, AL
I have a universal sway bar setup for sale. It was on the front of my rig. I have bent and polished aluminum arms (you can bend them back straight if needed) and a set of straight steel arms if you would like those instead. The kit uses 5/8" QA1 heims, spacers and jambs and both the frame and axle ends. I will have to measure the length of the actual bar. I have over $425 in this setup, asking $300.
Also I drilled and tapped the sway bar and use a allen head bolt and large washer to keep it from workling loose. Also uses DOM tube with tube adapters for the links.
