Sold/Expired Waggy Dana 44 3 link trussed axle / Hi Steer FS
TacomaJD
I LIKE CHEAP STUFF.....
13
Rainsville, AL
This is the waggy D44 that came out from under Brock's black Tacoma (ibrokeit) when he switched to tons front and rear. I used the chromoly axle shafts out of it and kept the gear set as extras since they are the same gear ratio for the same front end that I am running in my Taco. This was a complete axle hub to hub with Warn premium lockouts and all I took out was chromoly shafts, gears, and detroit locker. I also have some extra stock shafts and a brand new in the box Spicer u joint I will let go with this too. Has Hi Steer bar/knuckles also.
$300 for everything listed below, located in Rainsville, AL area. Text or call me (Josh) at 256-six three eight-5336. Been crazy busy with work lately and college just started back so if I don't answer, leave a message and I'll get back with you asap.
What I for sure have for sale:
* Wagoneer Dana 44 (think it's a 1989 model) trussed axle housing already set up to accomodate the All Pro 3 link kit and coilovers with all the brackets.
* the hubs/rotors/calipers/etc. is all in a box (you'll need all that apart anyway to put shafts back in it.)
* Hi Steer knuckles and bar are still in place on axle.
* 1 brand new Spicer 760X ujoint still in the box with full circle clips (strongest non-chromoly ujoint made)
Extras that come with it:
Got some spare axle shafts when I bought the axle and also still had good passenger side stock axle shafts/Spicer u-joint that were in my truck before the chromoly's were switched, so I'm almost certain I have enough axle shafts and u-joints here to make a complete set to where all you would have to buy would be gears and a locker to make this a complete axle. I will check soon and make note of what all I still have laying around and make an accurate list and post it here.
This is it in the back of my truck right after I left Brock's house from picking it up.
This is the way it currently sits. All of the outter parts are of course in a box and not pictured. Also will post pics of axle shafts if needed when I round everything I have up, and get a list.
:drinkers:
How much for everything, except the gears and locker you said you didn't have?
Give me a price and everything that comes with it, and also the width wms to wms.
Sorry for all the trouble, but interested
My email is [email protected]
Thanks.
sascommander184 said:
have the c's been cut and turned? what brand are that truss and link mounts?
No cut and turn. I daily drove the truck for 20,000 miles, 70+ mph on 37s. Aligned perfectly.
Truss and link mounts are from all pros taco 3 link kit, except the DS lower link bracket. We rebuilt it because the design was way weak.
Thanks for the info Brock, I only knew limited details about the axle as all I was really worried about when I bought it was the chromoly axle shafts, gears, and locker that were in it...which are now obviously out of it.
So far sascommander has the sale pending. Will update post if anything changes.
:drinkers:
Axle housing sold. Keeping the Warn hub parts around I guess since the housing is gone, might keep the shafts too.
Thread, closed. :drinkers:
