Weld on Super 60 High Steer- Tech Tuesday
BustedKnucklefilms
How to install Weld On Super 60 High Steer kit as well as make use of ball joint eliminators. The Super Duty Dana 60 axle is quickly becoming the go to axle for off road builds. We like to use their knuckles on our budget steering 14 bolt builds. The reason for this is you can run big bell RCVs and big rockwell size shafts and joints and all you need is our super duty dana 60 ball joint eliminator kit. Well then you need some way to run high steer to keep you steering up out of the rocks when rock crawling. That is where our DIY weld on dana 60 high steer kit comes into play. The kit comes with all the plates and spacers you need to get it done. Some grinding to get that perfect fit, someway to preheat your knuckles and a welder is all you need to get it done. If that is out of your skill set you can always either send in your knuckles to have us weld the high steer kit on using our jig or you can order a set of Dana 60 Super Duty knuckles from us with the high steer kit already welded on.
Are the 99-04 knuckles made out of the same material? I already have two sets i'm planning on using for a build. Not really wanting to replace with the 05+ stuff.
