Rock Crawling Forums
What paint/ coating for new enclosed trailer?
Reply to thread
Message
<blockquote data-quote="SnoFalls" data-source="post: 1426434" data-attributes="member: 16419"><p>Boiled Linseed Oil for the walls as a "sealer" (BLO will harden, the non-boiled stuff won't harden). It's a tried and true way to "seal" wood other than paint/varnish. It's also easy to re-apply from dings.</p><p></p><p>For the floor, you're looking at a "paint", and probably want it to be oil based. Most "gas off" pretty soon, some not so much.</p><p></p><p>BTW, a "sealer" will penetrate and harden to seal the wood. A "paint" will/can adhere, but does little to seal the wood. </p><p></p><p>IMO, cured BLO on raw wood seals it ... apply a "paint" surface if desired for color/traction. The "paint" will be what wears and gets most of the yearly touchup.</p><p></p><p>Google about "Boiled Linseed Oil" and wood finishing ...</p></blockquote><p></p>
[QUOTE="SnoFalls, post: 1426434, member: 16419"] Boiled Linseed Oil for the walls as a "sealer" (BLO will harden, the non-boiled stuff won't harden). It's a tried and true way to "seal" wood other than paint/varnish. It's also easy to re-apply from dings. For the floor, you're looking at a "paint", and probably want it to be oil based. Most "gas off" pretty soon, some not so much. BTW, a "sealer" will penetrate and harden to seal the wood. A "paint" will/can adhere, but does little to seal the wood. IMO, cured BLO on raw wood seals it ... apply a "paint" surface if desired for color/traction. The "paint" will be what wears and gets most of the yearly touchup. Google about "Boiled Linseed Oil" and wood finishing ... [/QUOTE]
Verification
Post reply
Today at 9:18 PM
Today at 7:44 PM
Today at 2:04 PM
Daves Offroad Supply
Latest: Daves Offroad Supply
Wednesday at 10:52 AM
Vendors
B
Latest: Bebop
Tuesday at 7:19 PM
