Sold/Expired Whats left of my YJ
alanevans10
Louisiana
-YJ tub and frame (no rust)
Has a couple dents in the hood
-Setup for 112 WB
-Motor mounts for a small block chevy
-All suspension parts including:
Way back shackle hangers on front and rear bumpers
boomerang shackles front and rear
all ubolts and plates for front and rear 60's (axle spring perches not included but available from Ruff Stuff specialties)
4 steel degree shims on front springs to correct pinion angle
front and rear leaf springs
rear shocks
antiwrap bar (axle brackets not included but available from Ruff Stuff specialties)
-1 3/4" DOM cage and tubework
Few dents in tube
-1/4" Flat skid plate
-Poly body mount
-Blue Torch comp cut rear armor
-Bluetorch rocker gaurds with tube step
-Winch mount built into front bumper
-2 suspension seats with sliders (one has a small tear 1 1/2" long)
-LED tail lights
-Aluminum V8 conversion radiator (bolts to grill in factory location)
-1 ton master cyl. and brake booster
-Steering shaft with steering wheel quick disconect
-orbital valve mount on frame
-valve in dash to lock back brakes
-Sony Marine waterproof radio cover in dash
-2 six circuit fuse panels
-Can include but not included, Headers, complete exhaust system that will bolt back in, ignition/start panel, accy. switch panel, SBC aluminum valve covers, bolt in rack that holds two propane tank brackets
$2500 Not looking to part out at this time.
Also have a set of 44" Tsl's on 15X10 8 lug DIY beadlocks w/ 2.5" back space Lots of tread, lots of rash on sidewalls and tread, one has been vulcanized, one has a plug in the sidewall $1000 for rims and tires, dont really want to seperate them.
Lots of pictures here: http://s723.photobucket.com/albums/ww240/alanevans10/1989%20YJ/
Parts are located in DeRidder La. 70634, Which is about an hour North of Lake Charles La. in the south west corner of the state.
Easily put back together, make an offer.
all build pics: http://s723.photobucket.com/albums/ww240/alanevans10/1989%20YJ/
