Sold/Expired Willis Flat Fender For Sale NEW PRICE$3000
MJP
39 Iroks
5.13 Gears and lockers F/R
44 front Never Ran, Chromoly shafts, CTM joints, Gold Warn lock outs, High Steer arms, new pads, rotors, calipers
60 Rear with locker Locker and gears are fresh install
new brake lines and master cylinder
new u joints all the way around
new wiring with relays and fuse box
new switches
propane injected
SBC
new plugs and wires
aluminum intake
headers
upgraded coil
griffin radiator with large electric fan
tranny cooler with electric fan
205 tcase
350 tranny
hydro steering just installed, new lines and ram
ratchet shifter
Summit seats with covers
6 point cage
jeep seems to gun good, starts easy and revs good. The front Dana 44 was just installed and when doing so it was completely rebuilt. New locker, 5.13 gears, chromolly shafts, ctm joints, gold warn lock outs, rotors, calipers, pads, and has high steer arms. Rear is a 60 with a new locker and 5.13 gears, still has drums on it. Motor is a SBC, seems to be stock with a aluminum intake and a set of block hugger headers. The HEI has an upgraded coil and new wires attached to it. Tranny is a 350 all the fwd gears work fine but reverse is not engaging. Tcase is a 205. Interior is simple and easy to take care of. Floors are dimand plate, Seats are Summit Seats and have covers on them, harnesses, ratchet shifter, new switch panels, headlights work, KC lights work, Tranny and radiator fan work when the ignition switch is turned on. Propane runs good and the supply line is NEW and its the good snake skin style. Steering is hydro, ram and lines are NEW, orbital was used and its ran with the stock pump. Feels like it needs to be bled.
Over all it seems to be a good Jeep. As with all rigs it could use a little tinkering and your own custom touches.
I dint know a lot about this rig as I bought this from a guy that was down on his luck and needed some money. Everything he said has checked out but I can not guarantee everthing as I did not buy the stuff and put it together myself.
Asking $4500 $3800 $3000 FIRM as it sits or I would sell it for $2500 if I get to keep the 205 and propane. I have a 203, a fuel cell and a carb I would give you to go with it.
Thanks
Mike
931-797-6676
Spring Hill tn 37174
Re: Willis Flat Fender For Sale
I like the green man, good luck with the sale.
price is OBO and ill consider some trades.
Guns, buggy parts, trailers, shop equipment
Thanks
Re: Willis Flat Fender For Sale NEW PRICE $3000
Ok its no Bull $hit time and you know this is a deal!
$3000 Firm
i have for trade.call 1931 339 7575 for info.
[attachment deleted by admin]
