Sold/Expired WOD SINGLE SEATER TWIN TURBO
extremetownie
WIDE OPEN DESIGN SINGLE SEAT CHASSIS $42500.00
It was built to take a beating. .25 main frame,A Pillar back all .188 , It has been work hardened
Motor: LXS 376, 6.2 LITTERS OF BADNESS LESS THAN A YEAR OLD ,TWIN 66MM PRECISION TURBO'S 86LB INJECTORS
Snow water and methanol injection
Tranny: Ptc turbo 400. REBUILT LESS THAN A YEAR AGO. PTC NITROUS CONVERTER. Cooler with separate fan
Transfer case: NO 205 WITH NORTHWEST FAB 34 SPLINE OUTPUT
Brakes: CHEVY 1/2 TONS WITH ABS Electric High Power Master Cylinder ABS
Axles: HEMAN FAB 14 bolt front. RCV 300 M axles. 4 inch .500 wall tubes WOD truss Reid Knuckles. Rear 14 bolt 4 inch .500 wall tubes OUVERSON 300M shafts WOD truss.
Spools YUKON front and rear.
Suspension: KING 2.5 COIL OVERS with reservoirs . 2" 7075 lower links. 2" 7075 uppers.
Wheels tires. 43 STICKIES. RACELINE beadlocks.
Driveshafts: 1410 .250 wall built by HEMAN FAB.
Sway bar: CURRIE .
Cooling: GRIFFIN RADIATOR WITH DUAL Spal fans.
AEROMOTIVE A1000 fuel pump and AEROMOTIVE regulator. BACK UP WALBRO PUMP
Fuel CELL is 16 gallon BLADDER TYPE.
New Corbeau seat
Crow Tacheting seat belts
Winch
