Sold/Expired Wtt/wts 1984 4runner doubler 5.29s 37s
tracker8wr
So here it is I bought this for my daughter for her first rig. It was in a sad state. We have fixed most all the function issues but its still ugly. It's fine for her on pavement and fairly flat ground as soon as the clutch is needed at steep angles hang it up. She can't handle the standard and an auto swap for this rig is stupid expensive. So I'm looking for a TJ YJ CJ truggy sammi tracker side by side needs to have an auto trans and at least 35s would prefer locked but not a deal breaker. I can add cash for the right rig.
Price: $3500
No ***le
This is what it has
1984 or so 4Runner
Exocaged (crap)
22r on propane
W56
double tcases (stock gears?)
Front FJ80 axle open and 5.29s. (Verified)
Rear FJ60 axle with Detroit and 5.29s (verified)
Front a rear Chevy 62" springs
Full hydro tractor stuff works now
37" Irocs
Square driveshafts
Pulled propane mixer and carb apart and installed new bladder and put the pieces in right and installed finger throttle.
Repairs made 9/2 and 9/3 this was after our first trip.
Cooling issue fixed new fan with shroud, radiator rebuilt, and water pump checked.
Found oilpan leak, new gasket installed.
Had some issues with the steering, return to pump was being restricted new hose fixed.
Rebuild one wire alternator installed and charging properly.
Some pics:
These where taken yesterday in my carport.
pyro31152 said:
If you were closer I would be all over this! Bump for ya
Where are you located. I've got a few wheeling trips planned to Ok, Ar, and Tn in the next few months. Also may just be down for a road trip.
muddinmetal said:
Damn what a deal! Awesome guy to deal with here yall!
Thanks man didn't know who you where at first. You getting some use out of those tires?
