Sold/Expired WTT/WTS CJ Juggy
bushhog750
Looking to trade for something similar to mine but 4 seater. Had no idea when I bought this that my girl friend and her little girls would love it so much. So I'm looking for more seats. I hate not being able to take them all at the same time. I have done my best to list all parts. I also have a complete 5.3 with computer that comes with the deal. I will be buying more stuff to complete the swap as time goes by. Any questions please ask, will entertain other offers besides a 4 seater but it must be turn key or very close and be nice enough that I cant say no, and I'll buy another rig for her to drive after the first of the year. No 4 cylinders or V6. Since I have to put a price $15,000 call or text anytime 678-614-0620 location is Woodstock, GA
76 CJ Juggy
- D60 front with spool 35 spline inner and outer with Yukon drive flanges, 14 bolt rear welded with pinion guard. 5.38 gears.
- 4 link front with 14" Bilstein remote reservoir coilovers and aluminum links.
- 4 link rear with Fox 16" coilovers and aluminum links.
- 119-120 wheelbase.
- Mostly 1410 joints. Front axle side joint is a 1350/1410.
- 4 cut and grooved 44" TSL swampers on 18 bolt MRT beadlocks, with one spare wheel w/o Beadlock ring and 2 cut and grooved spare TSL's.
-1995 LT1 new plugs, MSD wires with heat boots. Starts and runs on first start every time. Runs great.
- Aluminum radiator with shroud and twin SPAL fans with a relay and switch for each.
- RCI 15 gallon fuel cell with rollover vent.
- Turbo 350 transmission with B&M shifter.
- Twin stick NP205.
- New dash with autometer water temp, oil pressure and volt gauges.
- Brand new Optima yellow top mounted under dash.
- New wiring with new relays that's done very well. Not a rats nest under dash.
-12 volt guy 8switch panel with push button starter.
-Warn 8274 winch with in cab winch control and upgraded to heavy duty contactor box to replace the 4 solenoids.
- Matrix seats with Crowe 4 point harness.
- Roll cage has factory B pillar with the rest 2" Dom
- 4 LED Rock lights that are on a relay and switch.
- Rubbermaid Baja bin with aluminum Swag off road Baja bin lock box.
- Full hydro steering with single ended Psc ram, Psc steering valve, reservoir and heat sink cooler that radiator fans blow on for extra cooling.
- New hydro steering lines with a full set of spares.
- Oil pan, transmission and transfer case skid plate.
- Wilwood brake pedal with dual master cylinders, new pads and calipers.
