workinman789
- Joined
- Jun 20, 2010
- Messages
- 714
- Reaction score
- 0
yj rockcrawler this is a nice rig ready to go to the woods
engine is 350 has scat crank h beam rods srp dom pistons has afr alumium heads roller lifters roller rockers solid lift cam 292/296/630 lift has edlebrock fuel injection moroso oil pan has dui distributor with live wires est. 600hp
front end is dana 60 4linked with aluminium links 7/8 hiems blue torch fab truss has rcv axles 538 gears with solid drive flanges double ended steering ram
rear end is 14 bolt with 538 gears blue torch fab truss 4 linked with aluminium links and 7/8 hiems with pinion gard and disc brakes
drive shafts are built form thick wall tubing with 1350 joints and 1410 on front at case
trans is hd th400 built with reverse manual valve body and has 2500 stall converter case is 205 with big front output shaft clocked and twin sticked
has 9500xp winch mounted on the front
has tsl sx 43 stickies tires mounted on raceline beadlocks new with only 3 rides on them
has skid pan underneath has alumium radiator with electric fans has corberua seats with harnesses has 15 gallon aliminium fuel cell in the back
sure im missing something asking $19000obo may consider trades on a rzr 1000 located in prattville al 334-651-1020 josh
