Sold/Expired **Yota Off-Road Comp/Race/Trail Buggy**
trailtoy83
Member
attachment.php
If you have been involved in off-road in the last 4 years then you have probably seen this buggy in action or in several magazines. I have competed in this rig for the last 4 years with great success. It was built for the 2008 WEROCK/XRRA season, competed in KOH 2009, and has been running the ECORS series since 2010, along with several trail rides and local comps!
The specs.
CHASSIS
TOMMY GLENN 1.5X.120 DOM CHASSIS
1/8" 6061 ALUMINUM FIREWALL & FLOORS
1/4" 6061 ALUMINUM ROOF
83 TOYOTA PICKUP FRONT & CUSTOM SKINS
ENGINE
2000 PONTIAC SUPERCHARGED 3.8 SERIES 2
3.5" SUPERCHARGER PULLEY
JIM'S PERFORMANCE WIRING HARNESS
JIM'S PERFORMANCE CUSTOM PCM & TUNE
NGK IRIDIUM PLUGS
TRANS
904 3-SPEED AUTO
COMPLETELY REBUILT 1ST RIDE
ALTO RED CLUTCHES
TRANS GO FULL MANUAL VALVE BODY
SKYJACKER DEEP PAN
B&M SHIFTER CUSTOM GATES
DERALE TRANS COOLER W/ FAN
TCASE
STAK 2 SPEED MONSTER 3.0 RATIO
HEAVY DUTY OUTPUTS W/ 1350 YOKES
FRONT AXLE
SHAVED DANA 60 63.5" WMS to WMS
SOLID 6 LUG HUBS
4.11 GEARS DETROIT LOCKER
COMPLETE SOLID OUTERS W/ HIGH STEER ARMS
BRANIK CUT YUKON 4130 SHAFTS & JOINTS
COMPLETE SET OF 4130 SPARES AXLES & JOINTS
46 DEGREE STEERING
FORGED 1350 YOKE
REAR AXLE
SHAVED HP DANA 60 64" WMS to WMS
6 LUG
CURRIE/YUKON 4130 SHAFTS
FORGED 1350 YOKE
BRAKES
WILWOOD DUAL MASTER CYL SETUP
CNC CUTTING BRAKES
DISC BREAKS ALL 4 CORNERS
SUSPENSION
KING 2.5 16" COILOVER W/ RESERVOIRS
KING 2.0 BUMPSTOPS
CUSTOM TUNED @ KOH 2011
BARNES 4WD NEW REBUILDABLE HIEMS
3 LINK FRONT & 4 LINK REAR
FUEL SYSTEM
12 GAL JAZ FUEL CELL
2 WALBRO PICKUPS IN TANK
70 MICRO PRE FILTER IN TANK
10 MICRON AN FUEL FILTER
ALL AN FITTINGS & BRAIDED LINES
WIDE OPEN AN CUT OFF VALVES
STEERING
COMPLETE PSC FULL HYDRO STEERING
SUPER FLOW TC PUMP
2 TURNS LOCK TO LOCK
SUPER FAST STEERING NO LAG!!
DRIVE SHAFTS
CAROLINA DRIVELINE HD SHAFT
8" SLIP SPLINES
1350 & 1350 OFFSET JOINTS
1 SPARE FIT FRONT & REAR!
NO BINDING USES ALL 16" OF TRAVEL!!
OTHER
40" MAXXIS TREPS 95% TREAD
RACELINE MONSTER BEADLOCKS
ODYSSEY BATTERY W/ METAL JACKET
CUSTOM GRIFFIN RAD W/ 16" SPAL FANS
12 VOLT GUY CUSTOM SWITCH PANEL
80A MASTER KILL SWITCH
22" LED LIGHT BAR
WARN 9500 HSI WINCH
100' 3/8" SYNTHETIC LINE
CORBUEA BAJA ULTRA SS SEATS
BLUE TORCH LIMITING STRAPS
LOWRANCE BAJA 540C GPS
AUTOMETER GAUGES OIL, TRANS, WATER
QUICK DISCONNECT STEERING WHEEL
DUAL SUPERTONE HELLA HORNS
(2) 2.5LBS FIRE EXTINGUISHERS
This rig just placed 3rd for the year in ECORS series and 3rd last year in ECORS series with all podium finishes. In the 3 years of racing ECORS Ive had 1 DNF due to a broke rear axle shaft which I now have a complete set of Chromo spares.
The rig is ready to go! I keep this rig race prep at all times, you are not buy some beat up race rig. I keep all the fluids changed, Mobil 1 in engine, Royal Purple in Steering System. Transmission is brand new as of 10/2012, 1st ride was RBD this past weekend! Stak Tcase was rebuilt with 3.0 gears in early 2012, front axle has new wheel bearings and 1 new Yukon Joint as of 10/2012.
25,000obo
22,000 with 2.0 KING 16" Air Shocks & 90% 37" Comp Treps on 17" Raceline Monster Beadlocks
19,000 without Tires, Wheels, or Shocks
CALL 864-202-5850 I can sell with less parts for less money, also can sell with KING 2.0 Air Shocks and 37" Treps on Racelines.
Not really looking to trade as i am building a new race rig, but i guess ill see what you have to trade!
The Chassis is 48" with 100" wheelbase and 81" outside of tire. Also i am 5' 9" 170lbs and this rig fits me like a glove. If you are much bigger than this then the pedals would have to be reworked.
