Sold/Expired ZL1
blzrgb
Earth
Looking for a ZL1 out of a way new Camaro. Wish full thinking I guess. 662-279-1236
The motor he's looking for is the same motor that's in the newer CTSv.... He may not know that
LSA (CTSv) is a 6.2 SUPERCHARGED rated at 556
ZL1 (camaro) is a 6.2 SUPERCHARGED rated at around 585
ZR1 (corvette) is a 6.2 SUPERCHARGED rated at 638
All "basically" identical aside from boost pressure and piston design (and the heads on the ZR1)
I bet it would be a hell of alot cheaper to put a cam, and do a little head work and hang a procharger on a 6.0, and probally make more power
I'm old enough to have a hot rod article that said the zl1 69 camero also made 638 flywheel hp
Not quite that old (but close) but, yep, that 69' zL1 would be a sweet find. I always dream of finding one in the isle of an old barn somewhere.
Then I wake up.
I just sold a 69 camero L72 427 four speed car. Not an original but built just like one. As a matter a fact, I took the motor motor out for a while and ran it in my white jeep, was a blast!
Did the engine go with the car ?
The engine did not go with the car but is gone none the less. I've hade this motor since the 70's.and sold it to keep from building a rat rod. I was trying to finish my jeep and did not need to spend money anywhere else. I dd, however trade some work for a 489 big block built for off road that makes big power down low that is better than anything I've to date. It is a 15k engine and worth every horse. Makes 625 lbs tq. At 3500 rpms, unbelievable!
A buddy of mine has the bare block for a 69 Zl1 but dont think its for sale
489= 30 over 454 with 1/4 in stroke, eagle crank, corella rods, wisco 10 to 1 pistons, coated bearings, dane custom ground full hyd roller cam- 601 lift, 228-236 dur., brodex race rite alum. Heads, air gap intake, fast 750 cfm fuel injection, hexajust cam gear, fluid damper , makes 597 hp @ 6200 rpms and 624 lb ft tq @ 3500 rpms. The first trip out broke rear Rockwell axle and Detroit locker, replaced with oversons. Next trip out blew trany replaced with full race TCI trany. Backed off a little than went to harlin and broke front axle while turning only 1200 rpms. Question is can we afford that kind of torque!
Nice.......Any problems with the FAST injectors leaning it out ?
Only problem is fast floods it! Got a 600 hp fuel pump set to 60 psi. Had to move the oxygen sensor up in a header tube to get a good reading. It must have thought it was always cold and told it tobe rich. It's better now but still runs to rich, but that gives it quick throttle response.
