jabnasty said:Most rock bouncers will destroy the right side
knaffie said:My bet is that the race is won or lost on the rocks before backdoor. The guys with untuned suspensions and too much tire pressure are going to be in for a real surprise when they can't even keep it pointed in the right direction.
krackem said:They act as if y'all run 40psi in the tires![]()
Pumpkin said:It doesn't matter if the tire has 5psi or 50psi if it is turn 50+ mph. You will never see tire flex at that speed
sledneck said:Disappointed not to see Erik Millers name on the list.
We see it a lot around here, that it why they build the bouncers so tough. Have some broke doing it? Yes, but the beef up there weak links when they breakknaffie said:I don't see very many rigs landing on the gas after getting big air. If you want to break your junk, that's the best way to do it.
knaffie said:You can't compare PSI directly between a 44" TSL / hill killer tire and a 40" Krawler / U4 tire. I have owned them both and know that what is correct in one is definitely not correct in the other.
I don't know how much they run, but when I see a rig launch 10 feet in the air and land on its front tires on a rock and the side walls don't even flex, that is way too much. It's not hard to tell when a rigs tires are too hard. I get what they do isn't crawling, so more is necessary, but a lot of them are still ridiculously hard.
Sent from my DROID RAZR using Tapatalk
halcat said:Let's make the next duel be at Toms AOP bounty hill. I love bouncer, big time, and u4 cars too, but it's not a fair comparison .
crawlin85cj said:Again I ask...what do you think these tires are running for pressure on race day?
85toyo said:16 psi for KOH
Cole said:Hell my wife ran that much at all the SRRS events and climed cable hill with 20lbs in both front tires.
