zayne2427
There's only one way to find out
Located in cullman al 35055
256-347-2508 call or text anytime
Mainly looking for cash
It now has aluminum trail ready's and 40'' maxxis trepadors
Cash price Reduced for 1 week to $17,500 Cash 100% complete ready to ride
Thanks for looking
Single Seat Buggy
Front and rear steer Kingpin dana 60's
Chevy 4.3 with Comp cam and Turbo T3/T4 Hybrid on Propane
Turbo 350 Trans
Atlas II 3.8 case
16" Fox Coilovers front and rear
Full Hydro Steer Front and Rear
PSC pump and PSC Oversized High Flow Reservoir
High Steer Arms Front/Rear
Dana 60 410 Gears wt Spools 35 Spline Axles
Solid Drive Flanges
On board Welder
2 Propane Tanks
Rock Lights Front, Rear and Sides
8000 pound winch front (bad switch)
2000 pound winch rear
New axle seals in the rear and All bearing have been repacked and all hubs greased.
Upgrades (2014-15)
40" Maxxis Trepador Stickies on 17" Trail ready beadlocks
**01/2014 Engine Built**
Spent $2k on a bottom up rebuild
main bearings, cam bearings, timing set, oil pump, freeze plugs, rings, rod bearings
Stainless steel valves, valve springs
Exhaust valves
Marine grade head gasket
Hypereutectic pistons
Heads surfaced
Valves grind
Block bored .040
Polished crankshaft
ARP Head studs
10/10/14
Atlas II 3.8 installed
-new 3 piece front driveshaft
-new He-man machine (same guy that makes them for WOD) Carrier Bearing
-new Corbeau Baja Ultra wide seat ( I am 6'2 225 and fit comfortably with a helmet on)
-new PRP padded harness
-new Redneck lights 4.5" led lights on front
-new rock lights
-rear axle king pins rebuilt
Needs nothing and is ready to ride.
03/2015. 40" maxxis Trepadors on trailready beadlocks
Thanks
Thanks for looking
Single Seat Buggy
Turbo 350 Trans
Atlas II 3.8 case
Solid Drive Flanges
On board Welder
2 Propane Tanks
Upgrades (2014-15)
Exhaust valves
Heads surfaced
Valves grind
Block bored .040
Polished crankshaft
ARP Head studs
10/10/14
-new rock lights
Thanks
