baldduck74
- Joined
- Oct 19, 2013
- Messages
- 348
THANKS, plan is to plate front and back, waiting for the time to do my new ram mount to try and tie it all togetherThat truss is actually very clean looking. I like it. Everything you need and nothing else.
Yes sir, plan is to plate and box it with 3/16" with keyed simi vertical plates, 1/4" will be used at suspension attachment areas. Might have forgot to mention frames from a k10 I had siting aroundAre you going to plate the frame? IMO the additional stiffness will benefit you greatly in getting your suspension to work properly and consistently. I know the cage will help but it is really only as good as the foundation it is welded to.
