4 truggy build
megatoy66 said:
Very nice work!! It looks great! sorry I don't have door for you but I will see if I can find a reasonable one for you. :beer: :beer:
I appreciate it... If you come across someone who is looking for electric windows/door locks, I would like to trade the guts from the passenger side front and rear doors with someone with manual windows. I have no need for power accessories.
I still need a 4 runner driver door (preferrably w/out power). The driver rear door has already been replaced with manual guts...
Thanks for checking :cool:
are you gonna have room for the back seats? mine is super tight...
yeah, I put sat back there with the seats, etc and it was fine. I have two small kids that will ride back there most of the time anyway.
I like the runner btw. Gotta love copped up 2nd gens... :cool:
Got some more parts from UPS so I put the bodywork/sheetmetal work on hold to work on getting the motor, tranny and cases assembled.
I got rid of teh LSPV and ordered up this wilwood copy from speedway motors. Super fast shipping btw and cheap...
I went back and forth with what to do with my drivetrain since I am running a ford v6. I have two W56 trannies and already purchased my MC07 adapter and donor tcase. I decided to run the W56 behind the ford motor. I hope I don't regret it in the long run.
Advance Adapters doesn't sell a Ford small block to toy tranny adapter, only North West Offroad. I couldnt justify spending $700 on an adapter that may end up not working out. I decided to order a scatter shield from Speedway Motors. I got this idea off 4x4wire a while back....
The next step was to center the bellhousing onto the W56 and get ready to start cutting.
We created a fixture to hold bellhousing center with the tranny based off measurements taken off of the block. I am very happy with the end result. I used Socket Head Cap Screws that I had purchased long ago for my hub spacers and also re-used both bellhousing dowel pins. Took a long time....
more...
Sitting next to the stang' V6
And now mated to the motor... I still need to pull it apart to put a clutch, etc. in. I have a new Toyota clutch that obviously won't work so I need to sell that and buy a Ford pressure plate and clutch with the correct spline to match the tranny.
That was it for Saturday. Today, I assembled the cases and chim- crossmember. Pretty simple installation thanks to the 4RnrRick directions...
Next time, I plan to get the drivetrain mounted up. I'm going flat belly, so I will need to stock up on more sawzall blades..... That will have to wait until after the upcoming vasectomy surgery.
tj40ounce said:
:wtf: :DOH: :online2long:
err yeah the taco bell was getting to me, I meant to say I was mooching off of Taco Bells wifi until I got my fawking DSl Router from UPS....BTW let's see more of the body work I plan on bobbing mine and doing the graft just like this T4R.
:D
I plan to get down there again in a couple weeks. I go in for a vasectomy on Friday which will put a "crunch" on progress....
I couldn't remember who I stole the idea from for using a scatter shield for a bellhousing adapter.
That'll NEVER work. I can't believe you listened to... uh...
Call up Advanced and order the bits, or find a local place that can rebuild your clutch disk -- most major metropolitan areas have vendors that can rework clutch disks. Marlin Crawler may have this part on his shelf, as well.
Randii
Finally able to put a weekend in on the truck..
Started with a little more body work on the back of the cab.
My dad workin' it...
ready for primer and paint. Not perfect by any means, but good enough for a trail rig.
rattle can black. Not sure what color I want, but the paint at least seals up the body work, etc...
standard cab rear slider installed..
