Scott F.
It has the adapter plate to bolt the GM master to the Toyota booster. The master cylinder is included and worked with no leaks but can use for a core charge too.
Also included are brake line adapters for both ports so you can reuse the Toyota hard lines at the master. Cylinder bore is 1.125 I believe.
$25 shipped. I am located in Canton GA 30114
