Mortalis5509
I'm am posting up my tj for sale with a lot of good things on it. All are months old unless other wise noted
Why: I'm getting more into racing and won't less of a full body rig
Bad: th350 needs a rebuild, front side of the atlas is popping out right now, 1 vulcanized trep but doesn't leak, one of the fans on the trans cooler isn't working - this is 100% honest truth
Engine:
5.3, nasty cam (specs are at home for it), double beehive springs, push rods, rod bolts) - used motor
3qt accumulator
PSI harness and tuned motor...estimate close to 400hp
up graded injectors
Car pan
Hedders
Trans:
TH350 needs a Rebuild
TCI 2400 stall
Full Manual Reverse Valve Body
Suspension:
14" front King 2.5, lite tuning for the rig (used) 6" up travel
16" rear King 2.5, lite tuning, new 7" up travel
Radflo 2" bumps stops
Front and rear 4 link with ruffstuff 1.25" joints at top and bottom
Steering:
Howe steering with TC style pump
Cooler
PSC Double ended ram
Front Axle:
05+ SD axle
4340 RCV 35 inner and outter
Detriot
5.13's
Trussed to C's
New unit bearing, new spicer ball joints
Drive slugs
Rear Axle:
10.25 with Disc brakes
ARB
5.13's
Artec Tress
Cutting Brake
Transfer Case:
Atlas 4 speed
1:1, 2.73, 3.8, and 10.37
Tires and Wheels
5 sticky Treps
5 Racelines
Interior and Misc.:
Dual Radiators
Dual trans coolers
Corbeau Seat
PRP 3" harness
Music
Interior lights
Rock lights
12 volt guy switch pannels - switches that I don't have hooked up are are there - light bar, heated seats, 2 Aux switches, these work - 2 cig lighters for phones or whatever to charge
Warn 10k winch with synthetic line controlled from the inside
Polyethylene skid plates - they are 4 pieces - 2 boat sides, belly, and oil pan
cage tied into frame
Removable spare tire carrier
RCI 15 gallon fuel cell
Fuel return line cooler
Engine Cage
Storage rack in the back
Light bar in the back for back up lights, brakes, and a blue running light
Built a new frame when the build was started - so this isn't a factory frame
Spares:
New - water pump, thermostat, alternator
Stock 35 spline shafts from Ford
Spare set of skid plates
Thinks that about it
Engine:
3qt accumulator
up graded injectors
Car pan
Hedders
Trans:
TCI 2400 stall
Suspension:
Steering:
Cooler
Front Axle:
05+ SD axle
Detriot
5.13's
Trussed to C's
Drive slugs
Rear Axle:
ARB
5.13's
Artec Tress
Cutting Brake
Transfer Case:
Atlas 4 speed
Tires and Wheels
5 sticky Treps
5 Racelines
Interior and Misc.:
Dual Radiators
Dual trans coolers
Corbeau Seat
PRP 3" harness
Music
Interior lights
Rock lights
Engine Cage
Spares:
