Sold/Expired 1 Ton Tube Buggy With 402 Big Block, Turbo 400, 44" Cut TSL's $7,250
jcorlew24
Hendersonville,TN
Let me start off by saying this is not the prettiest buggy out there. So if you are looking for something flashy this is not for you. This rig was built for go not show. It is a very tough and reliable rig. This is a complete tube buggy built off of a K-5 Blazer frame. Here is the run down.
Engine
402 Big block removed from a 1972 Chevelle. It was built fresh this past new years. It has domed pistons with a 10:1 ratio and runs on propane. The engine is cooled by an aluminum radiator which has a tranny cooler and hydrolic cooler mounted on it with their own fan.
Transmission
Fresh Turbo 400 manual valve body with B&M shifter
Transfer Case
Clocked 205 twin sticked that has just recently been gone through
Front Axle
Dana 60 with chromolly outters, 5:38 gears, Spicer joints, Full Detroit Locker, High steer arms, Hydrolic steer, full differential guard, and drive flanges.
Rear Axle
Corporate 14 bolt with 5:38 gears, Full Detroit Locker, Disc brakes, heavily trussed, pinion guard, and differential guard.
Suspension
The front suspenison is on leaf springs with new Billstein remote resi shocks. the rear is 4 linked and sits on coil springs.
Wheels and Tires
The tires are 5 44" TSL super swampers. 3 of the 5 are brand new and 2 have been vulcanized. The rears have been cut removing every other inner lug and the fronts have been sipped. There are 4 beadlock wheels and 1 non-beadlock that is used for a spare.
Interior
The interior has plenty of room with 2 Corbeau seats and 5 point harnesses mounted in it. There are also front and rear mile marker winches that can be operated from in the cab. It also has a Vivair on board air system with storage tank.
Extras
I have 5 propane tanks that will go along with the sale, a hi-lift jack, 1 front spare drive shafts, the yokes and flanges to make a rear driveshaft, and a spare hydrolic hose.
http://i693.photobucket.com/albums/v...w24/buggy1.jpg
http://i693.photobucket.com/albums/v...w24/buggy2.jpg
http://i693.photobucket.com/albums/v...w24/buggy4.jpg
http://i693.photobucket.com/albums/v...w24/buggy3.jpg
http://i693.photobucket.com/albums/v...w24/buggy5.jpg
If you have any questions you can give me call at 615-456-7185. The price is $8,000 cash obo, but please no rediculous low ball offers.
Re: 1 Ton Tube Buggy With 402 Big Block, Turbo 400, 44" Cut TSL's $8,000
img]
Here you go sorry about that. Just let me know if you need anymore.
Any trades?
Yes, I would consider trades on a light weight buggy with built yota axles under it. This buggy works great but I would like to have something a little smaller to pull behind my tow rig.
Will put a little cash with my buggy for the right rig.
