tbacon38
- Joined
- Sep 4, 2010
- Messages
- 733
14 Bolt Driver drop front
Yukon 35 Spline outers
Yukon 14 bolt 30 Spline inners
Yukon Spool
Yukon Super Joints
Yukon Ring and Pinion
Solid Inner C
Solid Knuckle
Solid Diff cover
Artec Keyed high steer arms
1/2 ton calipers
300M Drive Flanges
Dana 60 Dually front hubs that have been machined down
Rev 14 axle seals
BTF Lower King pins
Reid Racing Brass Bushing upper king pins
Comes with everything except steering cylinder
The housing is cracked on the driver side letting the tube bend up a little, this would be an easy fix. Tubes are .75 Wall Dom, all you would have to do is straighten the tube in the center section and add a truss. I have been running it this way since the ARC finals last year. I am asking 4,000, obo shoot me aqn offer all I can say is no. Axle is located in Charleston,Tn Contact me on here or send me a text 423-667-1789. Thanks Going to pull it out and fix the cracked housing tonight and start adding a truss. I will be running this axle until I get my new one built this year.
Yukon Spool
Yukon Super Joints
Solid Inner C
Solid Knuckle
Solid Diff cover
1/2 ton calipers
300M Drive Flanges
Rev 14 axle seals
BTF Lower King pins
