1983 Toyota Truggy
Drivetrain:
22R on propane
Long tube header
New head gasket, water pump, timing chain, power steering pump, alternator
5 spd with new clutch
Dual transfer cases with stock gears in both
Suspension:
63" Chevy leafs in rear and toyota rear springs up front
14" bilsteins shocks in the back and 12" up front
1/4" wall square drive shafts front and rear
1/4" belly skid
Axles:
Front axle is 83 housing
5.29 gears w/ lockrite locker
longfield axles
Trail Gear upper and lower trusses and gussets and diff guard
high steer
TG braided brake lines
3" wheel spacers
Rear is 86 housing
5.29 gears w/ full spool
TG diff armor
factory axles
1 1/2" wheel spacers
37/14.5/16 Maxxis Creepy Crawlers like new been on less then ten rides on them
mounted on custom steel beadlocks 16x8
Warn x8000i winch
Optima Red top mounted between frame rails in rear
have 4 propane tanks that go with it
Interior
Has CB radio and sony cd player w/ 6x9 speakers behind the seats
stock seats with 4 point harnesses
heat still works and windshield wipers
factory harness controls headlights and rock lights
Asking $6000
Truck is very solid and built right. I have not been let down yet, it performs very well offroad.
I have a clear NC title in hand for the truck.
located in Greenwood, SC
Drivetrain:
22R on propane
Long tube header
Suspension:
1/4" belly skid
Axles:
longfield axles
high steer
3" wheel spacers
Rear is 86 housing
TG diff armor
factory axles
Warn x8000i winch
Interior
Asking $6000
