betteroffsingle
- Joined
- Jun 26, 2012
- Messages
- 136
SOLD
1996 Lincoln Mark VIII, 112K miles. Runs/drives good. Power everything, 32 valve 4.6L V8, 280 HP. My secondary vehicle so it sees little drive time though I have been driving it more lately. Only put 3K miles on it 4 years.
New radiator just installed 7/26, both power window motors are new, fairly new alternator and battery as well as upper/lower control arms and ball joints. New spark plugs right after I bought it.
It has a sunroof but I strongly advise against opening it as it doesn't like to close.
Whoever had it before me did their own headliner and didn't do a good job. It's not sagging or anything it's just done in some fleece like material and I don't care for it.
I have a short belt on it now to bypass the a/c compressor. Not because the compressor is bad as a whole but because the clutch hub on the front of the compressor (which you can buy without buying the entire compressor) needs replacing due to the clutch material being worn out.
Driver seat is pretty trashed under the cheapo seat cover (on it when I bought it)
Passenger seat is fine
CD changer in trunk doesn't work
$2000
$2000
