105 Inch Wheel Base Tube Truck with Bronco Panels
Four Link Front and Rear
14 Inch Walker Evans 2 Inch Coil Overs with Bump Stops
Limit Straps
Rousch 408 Windsor Dart Pro 1 Heads
Fast EZ EFI Fuel Injection System
8 Quart Trap Door Oil Pan
200 Amp Alternator
2.5 Inch Exhaust Ceramic Coated
Built C6 Hardened Input Shafts, Low First Gear Set, Reverse Valve Body
1500 Stall Converter
203/205 Doubler
Tom Woods 1350 Drive Shafts
PSC Double Ended Sterrling Ram, Pump, & Resouvier
Front Dana 60, HP 5.38 Spool, Alloy USA Inners, Yukon 35 Spline Outers
Poly Performance Drive Flanges, Great Lakes Diff Cover
Rear Dana 60, HP Full Floater 5.38 Spool
Hydro Boost Brakes
All High Pressure Lines are Steel Braided on the whole truck
Auto Meter Gauges
6AL MSD
Modified Reverse Lock Out Shifter
Corbeau Seats
Harnesses
Window Nets
15 Gallon Fuel Cell
Duel Optima Batteries
Aluminum Radiator
Trans Cooler, Hydrolics Cooler,
9000lb Winch Front
2000lb Winch In Back
39.5 Red Labels on 17 Inch Allied Bead Locks - Lots of Tread left
One of the safest trucks out there
All tig welded construction
Removeable Interior Panels
inside dim 48"
hight 76 1/5
belley pan 21"
shocks set @ 4" up trav
track with 83"
overall L 157"
Asking $25,000 Turn Key or $13,000 Minus Motor, Trans, Transfer Cases, and Fuel Injection
Motor and Fuel Injection was over $9,000 in 2010
New Dent Free Panels Available for an additional $1,000 in color of choice
Contact: Joe at [email protected] or cell (586) 524-0494
Truck located in Michigan
[attachment deleted by admin]
Limit Straps
200 Amp Alternator
203/205 Doubler
Hydro Boost Brakes
Auto Meter Gauges
6AL MSD
Corbeau Seats
Harnesses
Window Nets
15 Gallon Fuel Cell
Aluminum Radiator
9000lb Winch Front
inside dim 48"
hight 76 1/5
belley pan 21"
track with 83"
overall L 157"
