ridered3
Not Rigless
Up for sale is a 2002 Ford F450 Quad Cab (seats 6), 8'x12' Flatbed, 19.5" wheel Dually that is a perfect work truck/hot shot rig/tow rig/crawler hauler. Truck is a Cab and Chassis (C&C) truck so straight frame rails front to back. Truck is 26 feet long bumper to bumper and weighs 9,700 pounds. I bought it for personal usage as a tow rig for the Jeep and tractor, but it is honestly just too big for my purposes now that I have the GayzR.
7.3 Liter Power Stroke diesel engine with Turbo and Intercooler. 4 speed Automatic transmission. Odometer shows 227,3xx miles, but I have replaced a ton of parts in the last few months (details below). Truck is exempt from Emissions testing due to having a Gross Vehicle Weight Rating (GVWR over 10,000 pounds), and vehicle is pre-DEF, DPF, emissions etc. Being a F-450, Farm Bureau had to write this truck on a Commercial Insurance Policy. Full coverage for the truck was cheaper than it is for my daily driver car, which surprised me.
FRONT AXLE: 10 lug, 2 Wheel Drive (2wd) straight axle with disc brakes and good 225x75x19.5 Steer tires.
REAR AXLE: 10 lug, dually, Dana 80 Rear with a 4.88 gear (plenty of low-end torque), disc brakes, a locked differential (both sets of rear tires spin), and good 225x75x19.5 Drive tires.
INTERIOR: Manual locks and Manual windows. Vinyl flooring. Vinyl Bench Seats front and rear with custom fitted Seat Covers with extra storage built in. Center console for extra storage. Dash has switch for LED Backup lights to double as work lights. Hot heat and cold A/C.
EXTERIOR: 6-19.5" steel dually wheels. 6-good tires (2 steer & 4 drive tires), plus an unmounted Universal spare tire. 40 gallon fuel tank. Steel flatbed that measures 8 feet wide by 12 feet long. Has a wooden flatbed under the steel as well. LED backup/work lights. 2-Jobsite/Job-Box style toolboxes mounted in the bed.
I am the 3rd owner of this vehicle and done all the mechanical work on the truck in the last 6 months/2500 miles. Well maintained and detailed service records for the time I have owned this vehicle. No wrecks. Small dents/dings to front bumper and door from previous life as a hot shot rig. Small paint chips from general use. Clean & Clear TN ***le.
MECHANICAL-ALL NEW: Factory Injectors, Glowplugs, Valve Cover Gaskets, ICP and PCV Oil Sensors, Upper and Lower Radiator Hoses, Thermostat, Water Pump, Coolant Reservoir Tank, Driveshaft Carrier Bearing and U-Joint, and Front Main Oil Seal.
NADA Commercial Trucks Values for Clean Retail of $14,200.00. Asking price on Craigslist is $12,500.00 OR BEST OFFER, but will start with a Hardline discount of 11,500.00 OBO. CASH ONLY. Located in Rockvale (37153) right outside of Murfreesboro. Call or Text 931-three nine seven-3319 between 7am-9pm).
Can be sold with or without the following:
Toolboxes -$400.00. Seat Covers -$200.00.
LED Backup Lights -$100.00. Spare 225x75x19.5 tire -$50.00
