For Sale 2006 TJ RUBICON w LS7
bddisi
BDDISI
Cleveland TN
$42,500.00 NO TRADES! Location Cleveland TN
Posting for a friend, Please contact him. H Carver, VIA Email or text. 4237152684 or [email protected]
• TJ-2006-Rubicon -burnt orange color, original paint no rust • Half doors-doors keyed different and I have keys -soft top
• Lift kit-metal cloak aluminum 3"1ift - custom hex aluminum 2" longer front • Custom to move front end forward 2" - not l'ong arm
• Old school 5 on 5 1/2" bolt pattern custom both front and back
• Dana 60 rear end Hellical Locker 35 spline axles - custom axles have lifetime warranty if you don't go over 35" tires - Rear and front end custom 1350 yoke built by Hudlow Axle 706.858.8385
• Front end high pinion KJ 44 high center electric locker • Used ½" tubes and CJ 1969 Jeep C's - Disc brakes- old school lock outs Warn • Mickey Thompson - Deacon 38 Baha 35" tall racing tires & wheels -17" x 9" also 5" on 5 ½ bolt pattern
• Drive shafts by Chattanooga Drives Line 423.624.4194 -velocity joint rear front drive shaft straight 1350 u joint
• Rear end set on 3 degrees
• Lane Culver Auto Specialties in Huntsville, AL 256.882.2450 dino work - 15 gallon fuel cell in rear -
Z06 LS7 Corvette engine-Custom tuning 505 hp - new cam shaft - 340 liter/ hr custom fuel pump and all plumbing - fuel fill original location - 604 hp - 460 hp rear wheels
• Headers and aluminum radiator-electric fan thermostat controlled - Novak Conversions 877.602.1500 • Atlas 11(2) transfer case - 3 to 1 instead of original Rubicon 4 to 1
• North GA Transmission 706.820.4156 - L460E clutch pack built for 1000 hp - drag car type clutches
• Custom split transfer shifter by Advance Adaptors 800.350.2223 - custom atlas 2 transfer case • • • • • Scorpion Off Road 423. 715. 7805 - wheels, tires, atlas 2, new springs, 1" lift for driver seat, new column switch, most all parts purchased from Scorpion Off Road. Gated shifter - Wide Open Design Murfreesboro, TN 615.962.9135 Ellis Off Road 423.464.0798- custom motor mounts, custom bracket system for alternator, radiator, cross member, aluminum radiator over flow, new Ford drag link, panard bar, air condition brackets, twin 2 ½" stainless exhaust X pipe and custom mufflers original location - 39 tig welds to ma.ke it come out in original location Protech 423.790.5988- Dakota digital dash and wiring No custom roll cage
IMG 3014
IMG 3025
IMG 3030
IMG 3015
IMG 3028 1
IMG 3031 1
IMG 3023
IMG 3024
IMG 3016
IMG 3018
