RenegadeSRT
Member
- Joined
- Feb 8, 2011
- Messages
- 10
Chassis built by Full Throttle Off Road in TN
Assembled by Essentially Off Road in TN
Wheelbase is 112"
2003 Chevy Vortec 5.3 with block hugger headers
TH350 Transmission
Art Carr shifter
203/205 Doubler with triple sticks
Newly rebuilt front Dana 60 axle with all new bearings and seals
Detroit locker with 4.56 gears
New RCV Performance cv axles with lifetime warranty
New Rockcrusher knuckles with keyed high steer arms
North West Fab drive slugs
Bilstein 4" air/hydraulic bump stops
14 bolt one ton full floater rear axle with Detroit locker and 4.56 gears
Blue Torch Fabworks rear axle truss and pinion gaurd
Crane cast chromoly diff covers
One ton brakes
2†solid aluminum triangulated links front/rear with 1.25" and 7/8" Teflon lined joints
All U-joints are 1410
PSC 10†double ended ram full hydraulic steering
Rock Equipment 14†coilovers
Warn 8000 lb winch with Amsteel blue 3/8†rope
Rear mounted double core aluminum radiator
Front mounted transmission cooler
Professionally installed aluminum interior with racing seats and 5 point harnesses
Fabricated but uninstalled engine compartment covers
RacePak digital dash
12 Gallon aluminum fuel cell
¼†aluminum skid plate
LED headlights
15x10 steel wheels with wide aluminum beadlock ring and backside bead reinforcement
44†Super Swamper Boggers, new fronts (not in the pictures) and southern cut rears
Click link for pictures and full ad
http://pirate4x4.com/forum/showthread.php?t=979774
[attachment deleted by admin]
Wheelbase is 112"
TH350 Transmission
Art Carr shifter
One ton brakes
LED headlights
