Sold/Expired 2011 Toyota based 2 seat buggy! Price Reduced (SOLD )
Jep72m
Dawsonville GA
NOT MINE POSTING FOR A FRIEND!
Just finished in April, Tube chassis buggy made with DOM tubing.
Longfield Axles in front with longfield hub gears and ARP studs.
Six shooter knuckles.
New Rotors, brakes, brake lines.
Trail Gear Full Hydro Steering
Trail Gear Diff Armor
Spools front and rear with 4.10 gears
95% 39.5 Iroks on Beadlock Rims
All gauges are Autometer C2 gauges with blue backlighting
12voltguy switch panel
Dual TC with Marlin Crawler "clocked" adapter
Freshly rebuilt 22re with LC Engineering head, cam, lifters, valve cover
Got Propane kit
2.0 Sway-a-way 18" travel air shocks
Panhard Bar in Front
3 linked front
4 linked rear
3/4 inch cryo treated heim joints all around
Limiting Straps front and rear on axles and front shocks
Summit Racing Scat Procar seats
Aluminum roof and floorboards
Bomb proof motor mounts
Fully manual brakes with brake/clutch combo with master cylinders
16" electric fan
New radiator, clutch, all new hoses when engine was built
Warn M8000 on front with wireless remote and 4500lb tractor supply winch on back with remote mounted to rear tc shifter
RJS Harnesses with pads
Custom steering wheel with quick disconnect
Disc Brake Conversion in Rear with stock axles
(4) 2" Wheel spacers
Custom Built Rear Axle Truss with d ring
Diamond Plate Dash and Gauge Cluster
Red Top Optima Battery
GM High Performance One Wire Alternator with Flip Kit on Motor
Smooth W56 Transmission
Headman Headers with Header Wrap
Flowmaster 30 Racecar exhaust
Rear Driveshaft is Long Spline Trail Gear with creeper joints
Big Bolt Flanges
Two Piece Front Driveshaft with new carrier bearing
Marlin Crawler Chromoly Output Shaft
Hella Rear Backup Light
Very Capable
Asking $12,900 o.b.o.
NO SCAMS
404-379-0223
Re: 2011 Toyota based 2 seat buggy!
Price also has been reduced to $12,500!! All reasonable cash offers will be considered...Also can outfit buggy with swayaway 2.0 shocks for an overall reduced cost. Thanks....the owner.
Re: 2011 Toyota based 2 seat buggy! Price Reduced
Will take $11,000 firm with 2.0 18" travel Sway-A-Ways and will take off and keep Fox 2.5's for another project. The sway-a-ways are in new condition only used on maybe 3-4 rides.
Bump for offers!! This buggy needs to go soon!! :woot:
