Jwhit55
- Joined
- Aug 19, 2008
- Messages
- 382
Buggy was built 95% turnkey by jimmy in may of '12 and was completed in Aug '12 by me and my dad! Buggy has performed great each time i have taken it out and it has not left me stranded(knock on wood)!! I Don't need/have to sell the rig, i am just burnt out riding the same ol place every weekend and ready to move on to something different. Thanks for looking and please send me a pm if you are serious or want to know anymore about the buggy!! Will NOT part out and NO TRADES!!
Specs:
'12 Jimmy Smith motor sports chassi
1.75x.188 wall Dom lower frame, 1.75x.120 wall Dom upper frame
347 SBF w/Trick Flow fuel injection, jimmy smith headers
Aeromotive fuel pump/filter/fuel pressure regulator
C6 transmission w/ manuel valve body, Derale cooler w/fan
Atlas 4.3 t-case, 32 spline outputs,1350 yokes, cable shifter, Roark fab support bracket
Ford hp Dana 60 front axle, yukon inner and outer shafts w/nitro axle joint, reid racing knuckles, ballistic high steer arms, rpm drive flanges, 4.88 gear, detroit locker
Front axle has jimmy smith built tube truss with steering ram mount/guard
14 Bolt rear axle, blue torch fab disc brake bracket, blue torch truss w/pinion guard, 4.88 gear, spooled, ruff stuff diff cover
Axles have all new seals and bearings
PSC full hydraulic steering w/double ended ram
FOX 2.0 coilovers w/PAC springs
FOX 4in bumpstops on front w/wod cans
Aluminum links w/1.25 heims upper and lower
43" Super Swamper TSL SX stickies w/17" aluminum raceline wheels
Willwood dual master cylinders
Corbeau ultra wide seats
Griffin radiator w/dual fans and shroud. Installed and welded into place by Wide Open Design
Coolant is ran threw upper frame rail
Autometer carbon fiber gauges w/tach and shift light
Art Carr shifter
Grade 8 hardware used throughout the rig. 1in in heims and 1/2in on coilovers
AN fittings and stainless hose used for fuel/trans/oil/steering cooler lines
UHMW skid plate
$47K FIRM
I am sure that i am leaving something out and like i mentioned above shoot me a pm with any questions and i will do my best to answer them. Buggy has been taken out almost every weekend since completed in AUG so it does have battle scars!!Please don't ask me if i am willing to part out. NO TRADES and dont bother low balling me!! Buggy is located right outside of Knoxville Tn. Posted link to build thread for pics but I will get current photos tomorrow!
http://www.hardlinecrawlers.com/forums/index.php?topic=17493.0
Some vids I stole off here
Specs:
Art Carr shifter
UHMW skid plate
$47K FIRM
Dvaughn1971 said:
Jwhit55 said:
