Sold/Expired 2012 Jimmy Smith Buggy
Jwhit55
Specs:
'12 Jimmy Smith motor sports chassis
1.75x.188 wall Dom lower frame, 1.75x.120 wall Dom upper frame
460w sbf w/fast fuel system built by Precision Race Engines (Have all the paperwork with specs on engine build along with dyno sheets)
C6 transmission w/ manuel valve body, Derale cooler w/fan
Hero 3.05:1 transfer case, 4.10 yokes, High Angle Driveline long slip driveshafts
Front 14 bolt axle, 4.88 gears, WOD c and knuckle, RCV 40 spline inner and outer shafts, wilwood brakes, solid drive flanges, crane diff cover
Rear 14 Bolt, 4.88 gears, artec truss, Mark Williams 300m shafts, aluminum hubs, wilwood brakes, rustys offroad diff cover
PSC full hydraulic steering w/double ended ram
FOX 2.0 coilovers tuned by EOR
FOX 4in bumpstops on front w/WOD cans
2in upper aluminum links w/1.25 heims
2.5in lower aluminum links w/1.25 heims
43" Super Swamper TSL SX stickies w/17" forged double beadlock raceline wheels w/coleworks rock rings
Willwood dual master cylinders and pedals
Corbeau ultra wide seats
Griffin radiator w/dual fans and shroud. Installed and welded into place by Wide Open Design
Coolant is ran threw upper frame rail
Autometer carbon fiber gauges w/tach and shift light
Art Carr shifter
Grade 8 hardware used throughout the rig. 1in in heims and 1/2in on coilovers
AN fittings and stainless hose used for fuel/trans/oil/steering cooler lines
UHMW skid plate
$70k
Buggy is in great condition and ready to ride. I am not looking for any trades so please don't ask also not willing to part out! I am very firm on the price so again please no low ball offers. I am sure that I have forgotten to list some things but if you're interested pm me on here and I will give you my contact information. Thanks Jamie
WTF. Bump for one badass buggy even tho it's a ford :flipoff1: :flipoff1: Hahahaha. Good luck with sale. Someone will be getting one bad bitch here
Dang didn't thank you would ever sell the buggy good luck with the sell and are u just done with it or got plans on a new buggy
Something different..if it sells it sells if not no big deal!!
kmcminn said:
Is it hard to take out the front carrier with the ram mount tubing so close?
Nope comes right out, but it looks like it wouldn't though!!
This'll look mean with an LSX in it! ;)
Seriously though. ..this buggy is show quality stuff. It's beautiful and every time I've seen it at Windrock it's made short work of anything in front of it.
It comes right in and out. After the carrier comes out from the housing you slightly turn it and it will pull right out between the tube work.
Good luck with the sale.
Bump for dang sweet buggy! What kind of locker you running in the front?
So what the hell are you going to do to upgrade from this? Don't get much better than this unit except needing a bowtie!
Toyota!! Well I think I'm just gonna keep it, too much time and money to just up and sell!! Plus the look on y'all's face when I wax that ass is priceless!!
You just better hope they don't start a downhill comp!
Price just went up on this bad sum B. Tested and tuned. Great job Jamie.
