86tank
Posting for lay. Any questions message him on here or call or text him at 205-388-9730.
Chassis was built by Jimmy Smith and completed in June of 2012. It is .120 wall dom with some .188 in the main frame rails. Only 2 dented tubes one is on the shock hoop and the other is on the lower main frame rail Has an LS1, TH350 and a 3.0 Atlas case. 1410 drive shafts front and rear. Front is a Vertical Limits built 14 bolt with Solid knuckles and inner c's. Also has a new set of rcv axles. Rear was also built by Vertical Limits. It is a Rockwell 14 hybrid with Overson 16 spline chrome moly shafts and Wilwood 4 piston calipers. Both axles have 4.56 gears and PSC single ended rams. Tie rods have 1-1/4 heims. Links are 2" .250 wall Dom except for the rear lowers which are 2-1/4" .500 wall Dom. Has 1-1/4 heims on all the links also. Tires are 43 sxs on 16.5 MRW double bead locks with Coleworx outer rings. Price is $28,000
He's also willing to sell just the chassis with everything but the drivetrain and engine harness and steering for $8500 and can include the rear axle with the steering setup for $4000
