Mx_racer_36
- Joined
- Aug 22, 2013
- Messages
- 101
Ok I am looking to move my s10. The last option option 3 is how it is at the moment, option 1 will be without axles and option 2 will be with Rockwells and 44,47 or 49s
I will also consider trade for a rzr and cash.
OPTION 1, same as option 3 minus axles ,wheels ,tires,
Lo max will be replaced with stock 205, no rear steer electronics $$15k all u need is axles wheels tires. (All suspension links will be included.)
OPTION 2. Will be same as option 1 but rig will have Rockwells and wheels and tires under it. $$22.5k. Ready to wheel!!
OPTION3
Fourwheeler magazine 2014 top truck challenge champion!!
The Money Pit!
I have weeded out every weak link and the truck just works and holds together on 54s!!! I just took this rig to top truck challenge and we did not have to work on it 1 time all week! And took 1st or 2nd in every event!
The ONLY reason I am selling it is to build a 4 seater since my wife and I are expecting a kid in October.
Details:
1995 ext. cab s10
DRIVETRAIN :
*Gm 5.3l from a 01 silverado
*Custom rear mount radiator and electric fans
*rci 15 gal fuel cell with 4 walboro in tank pick ups,
* walboro 255 fuel pump, with all steel breaded lines
* freshly built th400 with boss hog torque converter, manual valve body
*ord 203/205 with a lomax 205, has 32 spline front output, upgraded HUGE rear output, 1410 yokes front and rear.
AXLE & SUSPENSION
* Gearhart Engineering custom 2.5/5ton hybrid steering axles with spools
* front and rear pinion brakes
* 16 inch Ori struts up front. 18 inch Ori struts in rear. All are anodized green.
* 4 link with all 1.25 hiems, BTF axle brackets
* double limiting straps on each corner and bump stops
Suspension cradle has a smooth 1/4 in skid plate across entire belly ( nothing for rock to hang on)
* all links are 3/8 wall and rear lowers are boxed fabricated rear links.
STEERING
* psc rockwell pump
* 2.5 in cyl front and rear
*Psc orbital valve and cooler
* Stazworks rear steer kit, with auto center, and indicator lights
FRAME
*2x4 3/16 wall tubing. With custom Exo cage made out of 1.75
Wheels & tires
*54in Mickey Thompson Baja claws on custom 5 ton double bead locks .
MISC:
* 42 in led light bar, Rock lights
* custom half doors with cup holders& set of full doors
* CD player with I pod hook up, kicker marine amp, 2 kicker marine 6.5, 8 inch sub, 2 6x9, and 2 4x6, Gets pretty loud!
* front and rear 12k lb winches
Rig is
103in wide
137 wheel base
Wieghs 7200-7300lbs
32inch belly
Feel free to make offer or trade and maybe something will catch my eye.
Asking cash price is 32.5k Obo
Open Possible trades or offers
Located in Duncan, ok
580-656-4273
I can text more pics.
Crawler, buggy, truggy, Toyota, f250, f350, diesel, lsx, cummins, rock crawler, 4x4, offroad, ram, silverado,
OPTION3
The Money Pit!
Details:
1995 ext. cab s10
DRIVETRAIN :
AXLE & SUSPENSION
STEERING
* psc rockwell pump
FRAME
Wheels & tires
MISC:
Rig is
103in wide
137 wheel base
Wieghs 7200-7300lbs
32inch belly
580-656-4273
