BigCountry
Posting for my buddy...Owner is Bill "Juicy Lushes" Himes , if you have questions call or text (865)-466-9289.
•Chassis is 1 3/4 .120 and .250 wall DOM/HREW powder coated Black, 124 Wheel Base, 24" Belly Clearance
•Engine is GM bow tie block 400 on propane, steel crank, 6" rods internally balanced, HvH aluminum angle plug heads ported and polished, big valves, 13 to 1 compression, makes 500hp
•Trans is a turbo 400 with hardened shafts and spragues, reverse manual valve body, 2500 stall converter, sidewinder shifter
•Transfer case is a divorced 205(fresh rebuild)
•Dana 60 front, 4.56 gear with a spool, Yukon axles, superjoints and flanges, solid knuckles
•14 bolt rear, 4.56 gear with spool, disk brakes
•16" fox coilovers all the way, fox air bumps on front
•44 boggers(cut) on Raceline Beadlocks
•Corbeau seats
•Warn winch
•MSD ignition and distributor
Everything new in 2015. This buggy is extremely well built and capable.
Owner is Bill Himes. Asking$32,000 $28000 obo, if you have any questions call or text (865)-466-9289.
"Juicy Lushes"
•Corbeau seats
•Warn winch
"Juicy Lushes"
