Sold/Expired 2016 Jimmys Bloodline Podium 3.0 buggy for sale
Status
Not open for further replies.
smokindave
New Member
$61,000 OBO
Lyons, CO
2016 Jimmys 3.0 Bloodline Podium(Built by Loren Healy)
LS3/480 with Holly Dominator EFI
Fully Dyno'ed by BoostCreep with Saved tunes
TH400 Transmission
4:3 Altas Twin stick transfer case with 32 spline front output
4" Pro Series Spidertrax Housings with 4"x1/4" wall heat treated tubes and tig welded
Spidertrax 3rd member with Gear Works 10" gears
5:38 gearing, fully spooled
Spidertrax knuckles
Spidertrax Ultimate unit bearing 6 on 5 1/2x5/8 studs
Brand new Chromoly Branix 300m 40 spline inner and outer shafts(have used spidertrax 300m shafts as back ups)
14" Wilwood break rotors with 4 piston calipers, with 6- 5 1/2 rotor hat
Wilwood high flow master cylinder
PSC full hydo Double ended Race cylinder with billet race pump
14" single pass heat sink cooler for power steering
Dual fan radiator, aluminum, with electronic thermostat, behind driver seat
Jazz 16 gal fuel cell with internal holly fuel pump
PRP Seats, lowered for taller drivers with 3" 5 point harness
Lowrance elite 5m Baja navigation
King coil shocks with reservoirs
King bump stops
Limiting straps
custom rear sway bar
Plastic storage bin in rear
Operating head lights with blinkers(on toggle)
Ridged Lights, 8" spot, rock lights
9.0 Warn Comp winch
17x9 Trail Ready bead locks( some rash)
4 Newer 42x14.50x17 Maxxis Trep Comp Stickies( just finally broken in)
1 Brand new spare on TR beads. Never mounted.
Custom wrap with graphics from Impacted Wraps(A bit demonic!!. Can be removed)
Will include a set of ATX Chambers beadlocks (used)
$61,000 OBO
CLICK LINK BELOW FOR PICS
http://s44.photobucket.com/user/smokindavesbbq/library/
Hello, newbie here. can you send me your contact info or let me know how to get hold of you.
Thanks
Kevin
Thanks
Kevin
Seller hasn't logged in since the original post, but here's his email address:
[email protected]
May get a quicker response than on here.
Status
