203/205 doubler question
suzuki932
Active Member
ive got a 203/205 doubler set up and have had excellent service out of it,but ive noticed a small leak on the rear output shaft seal and got to investigating and noticed a small amount of movement in the rear output shaft probably bout .005or.006 thousands.so my question is, is that somewhat normal and i just need a seal or is my bearing failing and needs replaced.any help on this will be helpful.
My rear output on my 205 Has no play at all. do you know if the play is in the yoke or the shaft itself?
:dunno:Im pretty sure it's the shaft cause I took off my drive shaft and tightened the crap out of the yoke with a three quarter racket. :dunno:
