22re problem
Had that problem befor took forever to figure it out sounds like the regulator on the fuel rail by the fire wall passenger side there also a vacume hose comes of it. 17 mm 2 copper washers there about $100 new .the diapdhram dries out if its been sittng! good luck mike.
There is also a possibility it's the Start Injector Time Switch. The cold start injector is initiated off a different switch I believe, that's why it only runs for a second or two.
With the information givin there is almost no way to know whats wrong.
an unpluged MAF will do what you describe. so will quite a few other things.
Hey guys sorry for the lack of furthe info on my problem, but I finally found the problem and it was one of the wires coming out of the ignitor (green wire) The truck is running good except now I am getting a 5 1 code.
