Anyone intrested in a 2WD Challenge, and to keep it honest - All front driveshafts will be removed prior to the Event starting. The challenge will be running the course in only 2wd and using only your winch operated by a outside person. You can't help yourself by stacking rocks, logs or moving cones. The outside person can only handle your winch duties. You will be judged on a point system, running a set-up course and judged accordingly.
------------------ Intrested?
* We will need a place to hold this event
* We'll need point keepers / judges / safety operators to do crowd control
* some sort of prize offerings
* A few nicely set-up 2WD rigs to help plot out the course and run it.
A 3 staged event system would tally all 3 stages together to determine the winner. 1st stage would be easy, something of a challenge for all to try at least. 2nd stage would consist of a hillclimb and the final 3rd stage would be a all out to the finish line timed event.
1st stage, basic navigation and spotter advice.
*(Points taken for backing up / hitting cones)
2nd stage, hillclimb
*(Points taken for using winch / backing up / hitting cones)
3rd stage, Timed event
*(faster you run it, the more points you keep. Points taken for backing up / using winch / hitting cones)
We'll need input on the place to hold this, if intrests for it and who will donate the time and effort to make it happen for everyone. Tahuya might not be a bad idea, location. theres a rock lane and a few good little hills. Having Entry Fee's could be used for Prizes, Food for a BBQ lunch / dinner, Clean up.
If anyone is intrested... reply with your input / suggestions.
:corn:
:corn:
