Sold/Expired 383 Stroker Motor 600hp
alli85
383 Stroker Motor High Compression Solid Lift Roller 13.1
Comp Valve Train w/ Aluminum GM Performance Heads
Scat Crank H Beam Rods & Dom Top Pistions
Billet 680 Lift Cam
ARP Studs Through Out Motor
3 Way Bearing Timing Set
Holley Mini Ram Jet EFI
9000rpm 600hp (Race Fuel)
Receipts for Motor Build Totaling $8200
$5500 obo
If your interested and have questions Text or Call Roger 931-242-8013
Can text pictures & will upload them in morning
Pics
Got a short video of it running I can send to someone also.
Bump for hella motor. Have vid of it shaking the ground at ideal. Can send to whom ever
Not much action so here's the run down on price tag. Butlers performance built motor. GM performance aluminum heads. 190-202 valves. Titanium caps. Brass guides with no seals dew too the 9100 rpm. 520 lbs of closed spring press. 7/16 studs. Stainless 1.5 roller rockers. Solid roller lifters. 300 M push rods. Stud gurtals and guides. Billet 680 cam shaft. 3 way roller bearing timing set. Scat steal crank. H beam rods 12.1 dom top KB pistons. ARP studs in every thing.mullins valve covers. 7 qt pan. Edd Nix done all machine work. Made 620 hp with high rise intake and carb. Turned 9100. Holly mini ram jet Efi on it now with 8000 rev limiter. Race fuel only.not been run much. Was too much motor for set up. Post said obo so shoot a price. Can't hurt nothing
I think I rode with that orange buggy at GM the other week. He blasted bounty hill! The 6.0 motor in it than was bad ****. He said the"big" motor was for sale. This 383 for sale , I think, came from this buggy. If he called the 6.0 "little" motor, than the 383 could be bad ass!
Yeah that's him. This 383 would suck that 6.0 down the intake and spit it out the headers.
We heard it over there but didn't make it to the hill before y'all left I guess? The 6.0 sounded like it was on point!
6.0 is pretty hot but won't hold a candle to the stroker as far as hp. It has a hole lot of skinny pedal.
