4.3 to 5.7 conversion question?
yoda1888
Member
I have a chevy truck wit a 4.3 an 4l60e. Im putting a 5.7 in it an want to stay wit the tbi set up. Anybody know what all i wil have to change as far as wiring or computer? Help needed! ..
Thanks.
From what I have been told about doing the same swap in my S-10. It is all plug and play just change motor mounts and go. A 4.3 TBI will work on a 5.7 but the 5.7 TBI does have bigger injectors. The fuel pump and/or ECM do not know the difference in TBI's.
This is all hear say from me asking around about the same swap I have not tried it yet. Let me know what you come up with and if it works.
Not a Vortec, right?
Been there, done this. Change the injectors (throttle body is the same) to 5.7 and the chip or ECM . Good to go.
Thanks for the info guys. I'm going to be finishing it up tmw so bronco b. I,ll let you know how it turns out.
Went good only problem I'm having is a rough idle. I swaped the injectors an it will run the same with either computer. I cant tell the difference between the 4.3 an 5.7 computer
