truck-oholic
- Joined
- Dec 22, 2013
- Messages
- 456
Bought this AS IS a couple months ago and have decided to let it go to free up some cash.
Chevy king pin Dana 60 with 4.88 gears and Trac-Lok limited slip. Has Artec high steer and front truss with hydro mount. Artec parts were $650 alone. Original spring perches and shock mounts are still in place. Has a RockCrusher diff cover, Warn lockouts, and stock shafts. Roughly 68.75" WMS.
Again, I have not personally done any work to this axle but everything looks to be in good condition and there are no known issues. All the Artec stuff was a fresh install, never ran, and I believe the gear set was done at the same time. If full hydro isn't your thing you could still use the ram mount for a single ended hydro assist ram and run a conventional tie rod with heims below the arms and the draglink on top of the passenger arm. If someone wants the axle but not the Artec parts I'll remove them and include a WFO reverse high steer arm set if desired.
Looking for $1,800 cash but will consider full or partial trades especially if it's something I can flip fast for cash.
Located in Spring Hill, TN 37174.
Thanks,
Jesse
610 999 1546
Thanks,
Jesse
610 999 1546
