Sold/Expired 4 seater tube chassis buggy
wizzo
glasgow, ky
POSTING FOR A FRIEND
Contact Josh Thomerson @ 270-670-1391 or PM me here with any questions
$22000.00
Located in Glasgow, KY
Very capable, dependable buggy. Seats four normal sized adults well. Built this buggy in 2011 it has been beat on and used. Buggy has dented tubes and rock rash. It is not a show buggy, so please don't waste my time. Cooler goes with.
Interior: corbeau ultra seats up front with PRP 2" belts. Rear seats corbeau ss need replacing.
Engine: LQ4 6.0 bored .020 over, stock crank and rods, Mahle pistons and rings. Stock 243 heads with ARP studs, BTR double springs, ***anium retainers, hardened pushrods, adjustable timing set and oil pump. LS7 lifters. Custom ground camshaft.
Trans: th350 with ultra bell built by local reputable transmission builder. 2200 stall could use more.
Transfer case: 203/205 doubler with Ford front output.
Driveshafts: all 1/4 wall DOM with 1350 joints.
Front axle: Super duty high pinion 60 re-tubed for passenger drop. Reid knuckles with keyed highsteer arms, single ram psc steering behind axle. 5.13 gears with full spool, Yukon shaft and super joints.
Rear axle: 14 bolt w/ 5.13 gears and welded carrier
Links: all 1 1/4 heims 2" uppers 6061 and 2 1/4" lowers 7075
Shocks: 17" remote reservoir bilsteins all around.
Brakes: dual pedal willwood
Wheels and tires: KMC wheels with wore out 43 stickies.
Haul three passengers in comfort and still have the capability to climb Bounty Hill at GMP. :driving: https://m.youtube.com/watch?v=LrgYTAi41j4
This is one heck of a good rig. It will hurt your feelings trying to follow it.
This thing flat gets it. I have seen it do some incredible stuff and we know the driver sucks so it MUST be the rig. :flipoff1:
