Used but good shape from front Dana 44 Pass side drop J-10
Yukon super joints to replace 297x and 760x spicer $100
(with grease and grease gun) These are indestructible in a 44.
1 yukon and 1 superior chrome moly dana 44 stub shaft $50 and $75
Dutchman inner chrome moly shafts for dana 44
Long side is 35 1/4"
short side is 16 1/2" $150 set.
Chevy/wagoneer backing plates and calipers $50 a set
Dana 44 housing pass side drop with Chevy flat top knuckles, with high steer arm for cross over steering w/ 7/8" tie rod and heim joint drag link included. $250 set also has castor correctors which give an additional 2 deg castor. ( helps get the pinion higher and maintain perfect steering geometry.) Includes ball joints. Needs axles and carrier. I have stock assemblies and chrome moly axles for this housing for sale below.
Stock J-10 dana 44 inners and outers complete and still assembled w/ joints. $50.
Wagoneer HD 1/8" thick front dana 44 diff cover $20
Same diff cover but with re-enforced front plate welded on $20
Jeep J-30 power steering box ( 3 1/2" big piston) 1 ride on it. $100. Paid $150 in october. Steers well with 38" rubber.
YJ 4" front springs, main leaf on one has small bend but serviceable and very flexy) $40 set
52" half ton chevy rear springs with fairly new main leafs and eyes cut off original main leaves and used as second leaves. $50 a set. These are original SOA springs!!!
[email protected]
[email protected]
