Hughes 2800 converter, Fresh rebuild with red clutches, reverse manual VB, AA adaptor for Atlas w/ mount, Stak, Dana 300. It has a 27 spline output shaft. The top two must mount holes on the bellhousing are broken. The bolts still tighten and it was run this way in a buggy with no issues. Also could replace bellhousing with aftermarket. You can see it in pictures. Also note the fluid on the floor in the last few pictures is not from this tranny, it has no leaks, the fluid is from the NP205 next to it which has many leaks.
Looking to trade for some 38" tires for 15" wheel or some kind of doubler set up for my NP205
Located in Yorktown, VA
