Ok, in my jeep is a 700r4 w/ 23 spline output that was used to bolt up to an NP231 t-case. I have overheated this transmission in the past and want to replace it if possible. I want to swap in a 700r4 w/ 27 spline output to use with my doubler. I could change the input of the transfer case if needed to get me by.
So I have a 700r4 w/ a 27 spline output but the bellhousing is not the same as what is already in the jeep. The bellhousing for the one in the jeep goes 2-3 inches forward of the torque converter while the one i was hoping to install is pretty much flush with the torque converter and will not bolt up.
The one already in the jeep has a "V" stamped on the case while the one i want to put in has a "K". Searching the internet has come up empty to this point. Does anyone have any insight on this.
Thanks,
Bobby
Thanks,
Bobby
