ridered3
Not Rigless
Glad to see there is light at the end of the tunnel for this build.
wayne86 said:She's a runner! Flowmaster exhaust for the win! It had a Magnaflow on it before and it crackled and popped horrible. I loaded it and unloaded it and drove around without brakes. I broke a bleeder off and had my cutting brake plumbed wrong so I'll fix those this week. Still have to finish my skid plate and tie up a few loose ends. The coilovers need adjusted. I just tightened the coil nuts to the top of the coils at full droop. It's sitting a little low and hitting the bumps in the front at ride height. I think I just need to adjust the preload? So still have to figure that out and get my oil pressure sensor working. Other than that I'm going to bust my ass this week and try to get down to Wind Rock on Sunday and Monday to ride for a little bit. Either way, my wife and I are taking the RZR down at least to ride with some friends that are going down Thursday through Monday.
https://www.youtube.com/watch?v=K1jPV9TN_90&feature=youtu.be
bbtank45 said:1-2" of preload and 150psi of nitrogen and see where it sits...... what ive found to work. Have you messed with the valving yet?
Beerj said:I'm no expert by any means but it sounds like your spring rates might be a little light. Did you add any more preload? Also, a little driver's side sag when you get in is probably normal. Even then, it probably squats the passenger side as soon as you hit the gas anyway. By the way, great build!
Beerj said:I think the 4" of threads showing part is basically their way of indicating either too light or too short of springs. I believe 16/14 springs are the norm for 14" co's but I think even then it's really only to keep the springs from jangling at full droop. With mine (Fox's), I set them to the minimum 1/2" of preload. That sat nearly an inch high but they quickly settled right on at 7" up/down.
I've had it out twice. Had an absolute blast both times but my brakes still suck...BAD. I'm not real sure what to do next with the brakes. I'm about to take it to somebody and let them deal with it. Other than that I just need to start tearing it down for paint. I'm thinking about relocating the steering ram to the front and building a guard for it. Behind the axle is cool but I have to take the high steer arm off to take the brake calipers off. I think it also needs a tune. It sounded and felt a little under power on the last ride. So once I get all back together I'll get it in for a good dyno tune.ridered3 said:Got any updates?
wayne86 said:I've had it out twice. Had an absolute blast both times but my brakes still suck...BAD. I'm not real sure what to do next with the brakes. I'm about to take it to somebody and let them deal with it. Other than that I just need to start tearing it down for paint. I'm thinking about relocating the steering ram to the front and building a guard for it. Behind the axle is cool but I have to take the high steer arm off to take the brake calipers off. I think it also needs a tune. It sounded and felt a little under power on the last ride. So once I get all back together I'll get it in for a good dyno tune.
I started my own business June 1st too so I've been a little behind on getting any work done on the buggy.
ridered3 said:Glad you are still tinkering with it whenever you have time. Bebop is a big fan of hydroboost and was talking about it some this past weekend at RBD. He'd probably be able to help tech wise on that front.
Congrats on the new business!
ridered3 said:Saw some of your pictures from riding last weekend.
So updates on the juggy are needed in the build thread.
